Block priming plug
Old Sep 9, 2016 | 12:50 AM
slow goat's Avatar
slow goat
Default Block priming plug
I haven't started/run my car in about 7 months. It has undergone a cam swap, new heads, lifters, and a blower. I have made an improvised priming tool using a garden sprayer. I need to know the size of the priming plug so that I can buy a fitting to mate to itName:  photo480.jpg
Old Sep 9, 2016 | 07:11 PM
KENS80V's Avatar
KENS80V
M16x1.5
https://www.summitracing.com/int/par...2268/overview/
It uses the same size threads as the oil pressure sensor behind the intake manifold.
Old Sep 9, 2016 | 08:23 PM
xBoostx's Avatar
xBoostx
Charge the battery take spark plugs off remove fuel pump fuse disconnect the ignition coils harness fill up oil filter pour in the oil and crank it till oil press goes up it sure not take very long at all.
Old Sep 9, 2016 | 08:27 PM
CMY SIX's Avatar
CMY SIX
push the throttle to the floor hold it down, push start button, it will not fire and will stop cranking when you take your finger off the button
Old Sep 10, 2016 | 12:32 AM
SlowBusa08's Avatar
SlowBusa08
what he said... matter of fact I just did this to prime my new ERL build.
Old Sep 10, 2016 | 05:24 AM
slow goat's Avatar
slow goat
Wow, I didn't know this. Thanks gents.
Old Sep 11, 2016 | 10:36 PM
xBoostx's Avatar
xBoostx
Thanks for the tech tip cool stuff.
Old Sep 20, 2016 | 08:08 AM
slow goat's Avatar
slow goat
I forgot to mention that this is also a new melling stock replacement oil pump. After trying to turn the motor over, we get no pressure after running the motor for 15 seconds. The question now is, what PSI are you guys priming the oil gallery's at and how much oil are you forcing in there?
Old Sep 20, 2016 | 09:37 AM
KENS80V's Avatar
KENS80V
20psi is fine and enough oil until you see it at the rockers.
Old Sep 21, 2016 | 12:45 PM
cclive's Avatar
cclive
The gauge on the dash should not register until the motor starts so you won't see oil press there even if turning the motor over for a long time.
Old Sep 25, 2016 | 08:41 AM
gbrtng's Avatar
gbrtng
Kinda makes me wonder how the factory preps an engine for its first start ...
Old Sep 25, 2016 | 10:22 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Hint: They don't
Old Sep 25, 2016 | 05:56 PM
gbrtng's Avatar
gbrtng
Oh, the humanity ...
Old Sep 25, 2016 | 06:06 PM
CMY SIX's Avatar
CMY SIX
When I installed my NEW melling oil pump I poured some oil down the pick up tube hole and rotated the center of the pump by hand, installed the pump{little messey} put every thing together primed engine like I said 3 times took foot off gas pedal pushed button and WA-LA! instant oil pressure!
To Block priming plug
