G6X3 cam questions
I plan on buying
-G6x3 cam
-Texas speed 1-7/8 long tubes
-3" x pipe no cats
-dyno tune
Couple questions anyone have a
similar set up and can share whp/tq
also anyone have specs on that cam? I can't find it anywhere.
Can I swap that cam with out any other head work/ valvetrain etc?
Really looking to be around 500ish whp
I plan on buying
-G6x3 cam
-3" x pipe no cats
-dyno tune
Check this thread for details.
487 rwhp G6X3 LS3 A6 Corvette, *New shop record stock headed LS3*
Time slip from bracket race today.
You will need new valve springs, retainers and pushrods for the new cam. Personally I would go ahead and install a new oil pump, timing chain, and harmonic balancer while you're in there as well. Is it necessary? No. But I did all bag for peace of mind.
Call LG Motorsports to get the scoop on what you need to optimize it.
How streetable is the cam?
Can you post videos of your exhaust?
487 is nice and since I'm a 6speed "I should make more power"
I'll be going to NicD from Arizona to get tuned
and
probably another 800-1200 for balancer, chain, oil pump/waterpump?
Even when I bought cams for my previous cars etc....
all the company's list specs.
It's sorta iffy buying a cam blind.
I know this cam makes power but it be nice to know what I'm buying.
It be like buying pistons and saying give me high or low compression
And not asking anything else
I agree. I had initially wanted for my car, but couldn't buy the cam blind.
I know there is always a way to copy something with all of the scanning software that is out there now but no point in posting the answers to the test before it's taken right?
I'll be happy to answer any questions I can about any part of it but yeah I can't post specs on it.
DIes he can require valvetrain? And say I want to go to ecs or aa down the road would the cam work well?
I plan on buying
-G6x3 cam
-3" x pipe no cats
-dyno tune
There are a ton of videos, track times, and dyno graphs out there of the cam.
Now I typically like to speak on the conservative side of things so headers/cold air/G6X3 on a manual LS3 car will typically make 480-495 rwhp. A few of the cars have hit 500 with a few other bolt on's (under drive, ported TB......) but on the conservative side that is typically where they fall.
Ported heads can put it in the 520-530 rwhp range. The best we have seen on a stock short block on 93 pump gas was 540 rwhp and 570 on 104 octane with a built bottom end (stock 6.2L displacement).
Say I wanna go supercharge down the road with a ecs is this cam okay for that?
