Passing State Inspection
Old Oct 13, 2016 | 06:45 PM
Swad's Avatar
Swad
Here might be my last question on this, then I think I know what direction I'm going to roll ahead with. Can the x-pipe be swapped out of an ARH system while leaving the rest of it intact on the car? Can it be done fairly quickly and easily (ie: loosen a few bolts and clamps on each end of the x-pipe and remove)? I'm looking into just getting the appropriate part and then working with a friend of mine who works on cars regularly to do the swap ourselves.
Old Oct 16, 2016 | 10:42 PM
StKnoWhere's Avatar
StKnoWhere
How many mile do you drive a year:
Four years or older and driven less than 12,000 miles in past two years. Owner must have owned vehicle for two years and must be tested on-cycle (even model year vehicles test in even years, odd model year vehicles test in odd years). Give approved proof of odometer readings to department.
https://dnr.mo.gov/forms/780-1972-f.pdf
Old Oct 17, 2016 | 03:30 AM
Swad's Avatar
Swad
This is specific to emissions tests which only happen in the St. Louis area (other side of state from me).
