UPDATED: Rotor Recommendation
I have a 2012 Grand Sport Centennial and just bought the O'Reilly premium padlets that are made by Bosch for the front and rear and intend to replace the front and rear rotors with drilled and slotted or at least drilled rotors. I use my car for spirited street driving only.
Thanks in advance.
This works surprisingly well for me, because I won't see significant brake dust on my wheels for several days.
I'm betting if you really clean your current rotors, they will be dust free
Now, onto rotors. I've used Bosch, AC Delco, and Raybestos drilled rotors (even for HDPE and autocross events) and never had an issue with them cracking (even though others have). I cool mine down good between sessions, and I have the holes washed out really good before the first event too. So my recommendation for the street is to get the style that you like, and don't worry about the brand. NOTE - you should get MUCH longer rotor life with ceramics too, based on everything that I've read, and seen with others. Meaning, virtually all performance pads wear out the rotors more.
Finally, I know that Firestone in my area uses Centric or Qualis brand rotors for our vettes, and I've never heard of anyone complaining about them (again, I'm sure mostly for street use). Just more food for thought.
