Electrical power loss reason?
Old Nov 9, 2016 | 08:32 PM
iandm's Avatar
iandm
Default Electrical power loss reason?
will try to provide all the info. it has happened a few times where when i go to press start button it clicks and then i have to do it again. tonight i got in and hit it. one click and no power at all. had to use emergency door opener and then still nothing. opened hood to check terminals and then power came back on(i didnt touch anything) like the fob sensor was under there and sensed remote. any advice?
iandm's Avatar
iandm
2011 base newish battery
Old Nov 10, 2016 | 09:10 PM
wil692's Avatar
wil692
may want to check the battery cable connection at the starter.
Old Nov 10, 2016 | 10:32 PM
cclive's Avatar
cclive
The symptoms are exactly that of a loose or corroded connection to the battery. This could be the + or the - terminals at the battery or the + at the starter or the - at the engine block.
Old Nov 11, 2016 | 08:54 AM
iandm's Avatar
iandm
thanks. i took off positive cable and reconnected; it wast all the way down. It has fixed problem so far. I thought it was a more complicated problem since it only lost connection starting.
Old Nov 11, 2016 | 11:07 AM
cclive's Avatar
cclive
A connection that is iffy can be broken by the massive demand for current that happens when the starter motor is engaged...but appear to be fine when it is only supporting a few lights and the computers.
To Electrical power loss reason?
