Spark plug torque value??
Old Dec 1, 2016 | 06:26 PM
C U IN REARVEIW's Avatar
C U IN REARVEIW
Originally Posted by timd38
I had a bad coil and got that look.
How do you test for that.....supercharged motor( fyi)
*Car was running great*
Old Dec 1, 2016 | 10:13 PM
User Omega's Avatar
User Omega
You can use a megger or simply a J 26792 HEI Spark Tester to check the coils.
Old Dec 2, 2016 | 07:34 AM
C U IN REARVEIW
Never heard of either....where do I find these?
Old Dec 2, 2016 | 09:37 AM
C U IN REARVEIW
Compression test results...
Old Dec 2, 2016 | 09:55 AM
BlindSpot's Avatar
BlindSpot
I don't see any big deal with these compression readings. You're 8% difference. My first impulse, I am thinking you might have a fuel injector sticking at #1.
Old Dec 2, 2016 | 10:42 AM
User Omega's Avatar
User Omega
I would have the injectors cleaned before buying special tools. Those tools can be found online.
Old Dec 2, 2016 | 11:28 AM
mikeCsix's Avatar
mikeCsix
Originally Posted by AORoads
Does hurt to "toothbrush off" the plug threads? (not wire)
I would use a bronze/brass small wire brush if you want to clean the threads off and re-install. You have to be careful though not to leave any broken bristles caught in the tip.
If the plugs are really tight, they may be easier to break loose if the engine is warmed a bit. I haven't had to try this, but I think the aluminum head may warm up and expand a bit quicker, making the plug easier to break loose. This is supposed to work well on the Z06 brake pad screws too, loosen while the caliper is hot. When I replaced the plugs on my Denali at 100k miles, they all broke free without undue strain. The real issue was removing the spark plug boots. I ended up using a shoelace to do that...
