Spark plug torque value??
Nov 28, 2016 | 05:48 PM
Changing plugs in my car......they are in there very tight.....is there a torque specs for these being an aluminum motor? Or did my tuner just put them in to tight?
Nov 28, 2016 | 05:52 PM
Quote:
Originally Posted by
C U IN REARVEIW
First, is the engine cold?...must be completely cooled down before taking out the old plugs. Torque new plugs to 11 ft.lbs. No anti-seize if you're using NGK iridiums.
Nov 28, 2016 | 06:17 PM
Cold motor yes.....coming out REALLY HARD
Nov 28, 2016 | 10:38 PM
C U IN REARVEIW
Did the tuner put in new plugs?
Nov 29, 2016 | 04:50 AM
They should provide a little resistance at first. Once broken loose they will be super easy unless they are cross threaded or were over tightened.
How many miles since they were installed?
Nov 29, 2016 | 08:56 AM
Aluminum head, steel plug and no anti seize will make the plugs tough to remove because of galvanic corrosion
Nov 29, 2016 | 09:03 AM
timd38
That's "old school".
Plug manufacturers now plate the threads with a plating compatible with aluminum. Google NGK.
Nov 29, 2016 | 09:29 AM
BlindSpot
Well, I am old!
Thanks for the update information.
Nov 29, 2016 | 09:41 AM
timd38
Well, I am old!
No problem...I'm old too...took me a while to let go of the anti-seize...
Nov 29, 2016 | 05:49 PM
St. Jude Donor '15
"In honor of jpee"
Does hurt to "toothbrush off" the plug threads? (not wire)
Nov 30, 2016 | 12:10 AM
User Omega
About 6-7k miles
Nov 30, 2016 | 01:13 AM
So are they out now and everything is fine or are you still having trouble?
Nov 30, 2016 | 01:27 PM
User Omega
Yeah got them out....now this
Nov 30, 2016 | 06:51 PM
Why are you replacing them? Just curious.
Nov 30, 2016 | 07:11 PM
User Omega
#1 cylinder plug is much darker than the rest....just making sure nothing is wrong. Ie: compression test/scope
Nov 30, 2016 | 08:40 PM
Good to check it all out. I could be something as simple as an injector that varies in flow from the others. Keep us updated.
Nov 30, 2016 | 10:24 PM
User Omega
Will do
Dec 1, 2016 | 09:22 AM
C U IN REARVEIW
Check valve springs for broken coil and check rockers too on #1 cylinder.
Dec 1, 2016 | 10:06 AM
xBoostx
I had a bad coil and got that look.
Dec 1, 2016 | 06:24 PM
xBoostx
All springs looked good...didn't pay much attention to the rockers...but nothing stood out.
