Help please
Old Dec 18, 2016 | 02:52 PM
Al's c6 2007's Avatar
Al's c6 2007
Default Help please
I just bought my 1st C6 Corvette, LS2 2007. I was looking in the trunk and in the left trunk compartment I noticed a Kenny Bell boost pump, and then I opened the glove box and seen a Kenny Bell controller. My car came with a PSC1 procharger. Any help with these 2- items. Thanks Alan
Old Dec 18, 2016 | 02:55 PM
RicK T's Avatar
RicK T
What are you asking? Please clarify.
Old Dec 18, 2016 | 02:59 PM
Al's c6 2007
Is this Kenny Bell stuff for my tune possible.
Old Dec 18, 2016 | 03:17 PM
Mike's LS3's Avatar
Mike's LS3
K.B. boost a pump increasing the voltage to the fuel pump, thus increasing fuel flow while under boost. This prevents the engine from going lean at WOT. The boost a pump (BAP) works under boost when needed, without it your engine will lean out, detonate and go kaboom!
Old Dec 18, 2016 | 03:19 PM
Al's c6 2007
Originally Posted by Mike's LS3
K.B. boost a pump increasing the voltage to the fuel pump, thus increasing fuel flow while under boost. This prevents the engine from going lean at WOT. The boost a pump (BAP) works only under boost when needed without it your engine will lean out, detonate and go kaboom!
OK thanks for the information.
Old Dec 18, 2016 | 05:27 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Assuming it doesn't have some other supporting fuel system mods.. which it very well could (well, hopefully anyways).
Old Dec 18, 2016 | 09:00 PM
cclive's Avatar
cclive
Wow, 'kaboom'...that sounds bad.
Old Dec 19, 2016 | 08:51 PM
zrracer's Avatar
zrracer
St. Jude Donor '11, '14
The car may also have larger injectors.
I would dyno the car or better yet street tune it. Just to make sure everything is ok and working together.
To Help please
