Header Wrap??
Old Mar 8, 2017 | 05:07 PM
irok's Avatar
irok
Originally Posted by Not So Fast
Seems we always think that the GM engineers aren't as smart as we are. The starter sits next to a catalytic converter does it not, so I would think that they plan ahead for that as they get extremely hot, do the pipes get that much hotter ???.
Is the starter wrap really worth it?
NSF
wrap not needed.when you install your headers make sure you have enough clearance between passenger side header and transmission lines with Kooks.trany lines may need a bit of a tweek for clearance
Old Mar 8, 2017 | 08:40 PM
Not So Fast's Avatar
Not So Fast
Thanks, just did that today, they give you a little clamp that pushes the lines up a tad, gives about 1/2" clearance
NSF
Old Sep 20, 2019 | 08:14 PM
Pwalnuts's Avatar
Pwalnuts
3rd Gear
Originally Posted by rabrooks
I have been running my car with LG headers and exhaust system. I've always been concerned about all the components around the headers. I'm concerned about the wiring parts melting and I'm concerned about the trans and oil cooling not being as efficient as it can be. And of course, I've replaced a starter damaged by Heat Soak.
Since I had the engine out, I decided to do some extra heat protection. For those of you with experience with this, please tell me what I can expect.
I wrapped the headers with header wrap and spray coated them with the silicone header wrap coating. I reinsulated every wire in the engine bay that was in the area of the main heat source with either heat sleeves or silver heat wrap. A good bit the the factory installed heat protection material wasn't in great shape. Also, I covered the trans cooling lines. I used the Katech oil adapter so I could run larger Stainless steel braided hoses to the new larger oil cooler.
Based on all this, have I made improvements worth the effort. Share what you did and how well it worked for you
Roger
Originally Posted by Unreal
Not the only issue. Bigger issue is any fluid/leaks/etc soak into the wrap, and cause your car to burn to the ground. If you ever have a valve cover leak, or something like that, you are at risk of an engine fire.
I wouldn't touch it. Wrap the stater, and move on. Everything else is made to get hot.
I have no wrap on my header and to be concerned of a fire because of wrap i have unwrapped kooks with a built and procharged c6 clutch line got to hot with a heat sock on it and burst and the fluid hit the header and in my garage caught fire and until i got to the extinguisher 10 secs later was one hot fire . All due to uncontrolled heat in engine bay so idk what to say as far as the wrap being bad but mines getting it . Fuel line right above fire givin no fire extinguisher i wouldn't have a car or garage.
Old Mar 7, 2025 | 07:54 AM
Toys4Life C5's Avatar
Toys4Life C5
St. Jude Donor '21
This is an older thread but surprised no on chimed in on this.
Old Mar 7, 2025 | 08:31 AM
Dzv69's Avatar
Dzv69
NSF
I had the DEI wrap on my starter, when i took the car to a Corvette shop/mechanic for engine mods, my mechanic removed the starter heat wrap and told me air flow will keep the starter cooler. Not a single issue with my starter, even in Florida heat/humidity.
Old Mar 7, 2025 | 08:54 AM
Kingtal0n's Avatar
Kingtal0n
Insulating heat product of any engine in any power plant in the world improves its efficiency and economy because heat is energy
There are even secondary and possibly tertiary power plants that use waste heat from the first and second because it is so valuable
There is absolutely no performance based down side to insulating, wrapping, coating, other than the weight it adds I guess
Exhaust wrap for example is a performance enhancer. Not only does it reduce under hood temperatures and therefore intake air temperatures, The additional heat kept inside the exhaust system increases exhaust gas velocity which can have performance improving influence (depending on valve event timing, system pressure, fluid momentum(design of tubes)) helping to bring air into the the cylinder via flow work.
As with any performance improver, there may be down sides to certain mods, such as Exhaust Wrap:
-may reduce integrity of cheap thin wall exhaust tubes (not an issue for quality, thick walled and cast usually)
-itchy and annoying, I don't like exhaust wrap and I don't recommend if it you have better options because its a potential health issue
-sometimes appears unsightly, takes experience and sometimes a second attempt to get it looking good
Luckily you can do many other performance enhancing insulating things with no real down sides other than cost and time, such as
-reflective heat shielding in opportune locations to reflect radiative emissions
-Insulating ceramic/plastic/paint coatings for exhaust and cooling system plumbing
-Keep an Insulating plastic intake manifold
-Use large thick walled exhaust tubes for headers and exhaust system
Most OEM provide the thick tubes/manifolds and some form of reflective shielding around the exhaust. But we can do better and as the power output increases so should our attention to the heat the engine is producing as a byproduct
here is a example of junkyard shielding done for low cost to maintain a cool engine bay and cool engine coils , starter, etc...
