Center console
Old Mar 8, 2017 | 08:56 PM
jonesc6's Avatar
jonesc6
Default Center console
Hello everyone I have a 05 base automatic car an I want to replace stock radio it died. The question I have is when I disconnect battery the center console will not come out unless u unplug airbag switch in the middle? Will it be ok to unplug passenger airbag to get console out? How long do I have before it loses its memory or if it will at all? Any suggestions? Thanks
Old Mar 8, 2017 | 09:21 PM
EVRose's Avatar
EVRose
You won't lose anything with battery disconnected. Be sure to put the shifter in neutral first if you have A4 or you won't be able to get the console off. The airbag thing is only an indicator light. Check out www.kawal.net for a good tutorial.
Old Mar 8, 2017 | 09:27 PM
jonesc6's Avatar
jonesc6
Thanks so much I was worried bout airbag going off if I did something wrong.
Old Mar 8, 2017 | 09:29 PM
HBsurfer's Avatar
HBsurfer
You will have to re index your windows after you unhook the battery. As EV said, everything else will remain as is.
Old Mar 8, 2017 | 10:48 PM
jonesc6's Avatar
jonesc6
Thanks for your help hb surfer an ev rose. I didn't want to pay stereo shop 150 to install it.
To Center console
