SO getting ready to get this cam I have installed in my 2012 GS. Long story short and friends going to let me use his shop and lift, but I only have it for a day, which is ok because if I can use the lift to do the cam, that will be awesome and save me rolling around on the ground. My only concern is if I can finish the cam stuff, and just have the VS's to install, is it absolutely a terrible idea to drive the car home on the stock springs. Im only 2 miles from the shop, and it would be basically idling it home so I can finish the springs. The cam is 227/234 613/576. Thanks
Probably be a better idea to install the valve springs at home before driving to the shop to install the cam. I mean you're going to open the valve covers twice anyway and it definitely won't hurt the car to drive it with stock cam and aftermarket springs; where as the other way around invites a broken spring. I'm pretty sure 613 lift is way beyond what the stock springs can handle, they would be binding.
Yah idk what I was thinking, forgot about coil bind. But got it figured out, just going to do it all at home, don't want to be stressed about doing it all in 1 day.
