Harmonic balancer replacement
Old Jun 11, 2017 | 06:09 PM
Mizfitcreations2.0's Avatar
Mizfitcreations2.0
Originally Posted by Wilkinshc
Which is the proper puller and install tool?
pending on what balancer you have, you can is a harmonic balancer removal tool or a 5-6 ton pulley puller. Both will take it off easy. There are a few LS HB install tools. I used Proform. Main thing is not to use the HB bolt to install as you can mess up the crank threads
Old Jun 11, 2017 | 09:25 PM
Dano523's Avatar
Dano523
Powerbond PB1503SS
http://www.daycoproducts.com/part?ca...ber%3DPB1503SS
HB is easy to pull with a standard 3 jaw puller, but when you put the new one back on, do not use the HB bolt to draw it back on the shaft. the bolt will not enough thread engagement to the shaft threads, and you will strip the shaft threads.
You need to use a HB installer tool to seat the HB on the shaft, then you can isnstall the new OEM bolt with diamond washer and torque it to spec.
https://www.corvetteforum.com/forums...em-or-not.html
Also that comes in handy is a fly wheel lock.
Lastly, since the Powerbond is going to come slotted for a crank key, make sure to full the HB slot with some RTV before you install the bolt (enough to seal the slot, but not too much that your flowing it out the back side of the slot).
As for the HB Bolt, loctite and the stock OEM streach to torque bolt with diamond washer is still the best (one time use).
Old Jun 12, 2017 | 10:04 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
This removal tool works well on the stock balancer
Amazon Amazon
