Vitesse Throttle Controller, Reduced Engine Power
We are here to assist ANYONE that has ANY issue with our controllers. Feel free to call us or email with the details...
Yes, we've sold 1000's and very few have issues, maybe 2 or 3 in 1000 units sold !
That is why we offer a warranty on the controller.
We will always stand behind our products.
Thank you
Bob
When I found out my C7 had the same throttle lag i wasted no time in purchasing one for it which now has been in the car for 9 months and is working perfectly.
Bottom line is , no matter what it is , it can fail, it's how it gets handled is what matters , just look at all the A8 transmission failure reports with the C7 , you might think it was every A8 from the reports or the forums but it is fact only a small percentage of the auto cars or look at all the reported Shift flair issues with an A6 ...
I can't speak to the post above where the guy says Vitesse offered a small discount or the others that said that they did not get any help but I can say I am happy with both of my Vitesse units and the service, although some time the response was slow, I received from BOB
Dave
I have helped more than my share of people who had "issues" with the Vitesse and 99.9 % of the time it WAS NOT a problem with the unit . And then there were some where it was 100% with out a doubt , a problem with the unit
Did you provide details to BOB on when it was failing?
The reduced power mode will come up for many reasons , what was the code ?
Did you check your pedal voltage to make sure it was not a problem with your car and not the controller?
A flaky pedal or throttle body will pop the code and adding a Vitesse will only amplify the problem
Did you check the connections at the throttle body and the pedal as one member did above , this one is the most troublesome because it can be hard to get the connectors to snap into place
This is not a Vitesse problem this is a GM problem , look at all the airbag issues caused by the connector under the seat
Was the unit under warranty ? If the unit was out of warranty when it failed , while hard to swallow, giving a discount on a new one is better than nothing . If you are out of power train warranty and your trans blows , do u think that GM is going to give you and install a new transmission??
let us know the details ....dont just bash them
Dave
This voltage might vary depending on the state of the battery and alternator. If the voltage is not what the ECM is expecting ( out of range condition) it will respond with a reduced power mode , which any drive by wire system is designed to do . I think the C6 is more susceptible because we all know it has its starter solenoid and charging issues which cause variations in voltage . Newer battery, strong charging system , no seloinod problems = you will never have to recalibrate it which is the case 99.9 % of the time
Dave
Thank you
Bob
The Full Refund only applies for the first 30 days trial period.
Thank you
Bob
Within 30 days , you can get a refund
Sounds Fair to me ... I don't understand what the problem was ...
Dave
Ether disconnect it or just recalibrate it
Most of the time it's not the vitesse , it's the condition of your battery
What condition is your battery in ? Has it ever gone dead on you , how old is it ?
Or it's getting hot ....
You don't have the control box in a hot area like stuffed in between the carpet and the tunnel do u , it needs to be mounted out in the open , mine was wire tied to a wiring harness .
Or its not calibrated correctly, setting the low point is easy but the high point is where people struggle, make sure u are mashing the pedal on the floor while setting the high point .
If you still get the reduced power mode contact Vitesse
Dave
Dave
Thank you
Bob
I switched out to the new unit and everything worked great for about 5 months. Then... I started up one day and had a reduced power problem and car was running rough. I automatically assumed it was the Vitesse. Well, I disconnected the unit, fired up the car, and still had the problem and the car was still running rough. Finally got out my code reader and low and behold it wasn't the throttle controller, it was a coil error on the #6 cylinder. So I looked up new coils and was ready to order one, and as I was investigating which cylinder was #6 I found a loose plug wire. Plugged it back in and wah lah! All good. Hooked up the Vitesse, recalibrated and it worked perfect.
Teaches me to not jump to conclusions and look for the simplest solution first. Haven't had a single issue with the new unit, and it is also cheaper and easier to return to stock if necessary compared to the ECU-based option. Service from Vitesse was great as well. So, I guess you could say I'm a fan.
