Error code C0450-5A
Old Aug 20, 2024 | 12:55 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
If no 12 volts at the EBCM connector white wire plugged in but you jumped power to the white wire unplugged you can assume you don’t have a short to ground or open…if you have 12 volts at the hot wire you jumped and have 12 volts at the pigtail you probably don’t have high resistance…I always check for power at the “source” which would be AT the EBCM.
Old Aug 20, 2024 | 02:13 PM
JimSVette12GS's Avatar
JimSVette12GS
8th Gear
Thanks!
