Torque solutions engine/trans mounts
Old Jul 22, 2017 | 12:59 AM
C U IN REARVEIW's Avatar
C U IN REARVEIW
Default Torque solutions engine/trans mounts
Has anyone installed these? Look just like the phadt mounts....but $200+ cheaper.....
Old Jul 22, 2017 | 03:35 PM
C U IN REARVEIW
Old Jul 23, 2017 | 09:00 AM
CMY SIX's Avatar
CMY SIX
try Hinson I think their in Birmingham
Old Jul 23, 2017 | 12:42 PM
Larry Myers's Avatar
Larry Myers
I recommend the Hinson engine and transmission mounts. Increased nvh is minimal.
Old Jul 23, 2017 | 02:44 PM
timd38's Avatar
timd38
Same here. Very happy with the Hinson mounts.
Old Jul 24, 2017 | 10:49 PM
C U IN REARVEIW
Stock height or shorter ?
Old Jul 25, 2017 | 01:04 PM
Larry Myers
Mine are stock height.
Old Jul 28, 2017 | 11:18 PM
C U IN REARVEIW
Any real benefits to running the shorter versions?
Old Jul 30, 2017 | 12:06 PM
CMY SIX's Avatar
CMY SIX
if you need the room under the hood, that's why the shorter mounts
Old Jul 30, 2017 | 11:53 PM
C U IN REARVEIW
dont really need it,possibly easier to install maybe? Lower the center of gravity a hair?
Old Jul 31, 2017 | 06:35 AM
sccaGT1racer's Avatar
sccaGT1racer
Hinson told me not to use the shorter ones unless I have a clearance issue with the intake.
Old Jul 31, 2017 | 08:50 AM
Unreal's Avatar
Unreal
I would never run a pfadt style mount. Too many complaints unless it is a full race car.
Hinsons are awesome. I've had the stock height ones for past 6 years and no issues.
Old Dec 12, 2017 | 11:34 AM
FNBADAZ06's Avatar
FNBADAZ06
Have you heard of any mount failures with the Hinsons ?
Joe posted on a FB thread of mine that he sees a lot of failures with them
Old Dec 12, 2017 | 01:27 PM
CMY SIX's Avatar
CMY SIX
NO! install was easy anyway just support the motor under the oil pan and undo the bolts on the stock mount and take the mount right off the side of the engine block. done.
Old Dec 12, 2017 | 01:38 PM
double06's Avatar
double06
I thought about 2 months ago somebody had a neat design (they were beginning to sell) with a hockey puck type unit that could take the heat and looked like a pretty good and simple design.
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Havent heard of any. Mine been on few years with no issues. They sell a heat shield for them now I believe. At the time they didn't, and I just used the stock heat shield with them. Failures would probably be due to heat from headers.
Old Dec 12, 2017 | 04:10 PM
timd38's Avatar
timd38
You lose ground clearance with the Hinson lower mounts. I don't know how low your car is, but mine is real low and I don't need the loss of clearance.
To Torque solutions engine/trans mounts
Old Dec 12, 2017 | 07:47 PM
CMY SIX's Avatar
CMY SIX
installed mine with the stock heat shields, I have Kooks headers closest pipe is what 5 inches away? heat related problems? poly has a higher melt temp then rubber. Hinson mount is smaller in diameter thus farther away from the exhaust.
Old Dec 12, 2017 | 07:52 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
I never heard of failures. They came out with heat wraps for the mounts so I just figured maybe they saw some issues.
Old Dec 13, 2017 | 10:50 PM
CMY SIX's Avatar
CMY SIX
I've seen the heat wraps, but for the life of me I don't see how the mount would be getting hot any way?
