Uh... Is this the harmonic balancer?
30 miles later, I pull up to a light just a couple miles from home when the engine bay starts screeching and grinding like you would not believe. I immediately pulled over to find the following... When it comes to cars, I'm not entirely mechanic literate. So, correct me if I'm wrong, but this looks like my harmonic balancer has come almost completely out and is grinding into the passenger side axle or whatever that thing is...
Looking online, replacing that HB looks DIY-able, but what kind of job and costs and I looking at to repair that axle?
I just got done doing mine. It was quite the PITA!
Good luck
On edit, here's the rack out of the car:
Still, until I bought the car in April I'd been without a car and relying solely on my motorcycle for the last five years. So, I don't have any sort of car jacks, stands, etc. Even as a DIY job, this probably isn't going to end up being cheap unless a local co-worker has what I need.
Given your situation, you may want to outsource this one.
250 ft/lb torque wrench (my big one maxed at 150): $50
Installer tool (old bolt was tatered) : $50
16mm tap to clean up the threads : $20
hockey pucks for lifiting (needed these regardless) : $25
bore scope camera to see what was going on inside crank : $20
full timing cover gasket kit (nobody had the front seal in town: $45
I had jack, jack stands, full complement of metric sockets/wrenches/breaker bars etc. I probably forgot some things.
You'll need that belt too. Actually you need both serpentine belts.
What year is your C6?
OK Thanks, can you tell if the pulley assembly shifted off the rubber lined hub, or has the bolt come loose (or both)?
I asked about years BC it seems that 2005s had more (or most) frequencies of losing the bolt. GM made a change, but 2006s might have also used the old bolt design. ALL C6 years have failures of the HB, but in later years, the rubber fit is poor resulting in just the pulleys wobbling or leaving the hubs.
A challenge you're going to have in a DIY, is how much pressure is the HB exerting on the steering rack. The rack needs to first move upwards, before it will come out of its brackets. The HB might have to be cut off first. This will be tough w/o a lift.
Not sure what your plans are for replacement or future performance mods, but it might pay to look into an aftermarket HB like Powerbond or ATI. Both are far better and more reliable replacements than another GM unit.
If you have performance mods in mind, especially supercharging, it would pay to pin the HB while you're replacing it. Pinning this press fit unit to the crankshaft ensures you're not going to spin it or lose it again especially with the HP/TQ you can develop with boost. Also, the new style GM bolt is preferred. GM finally got that right.
When I pinned mine, I chose an extra step of capturing the bolt in the pinning as well. Now there is no chance I'll lose the HB or the bolt. There is only one other C6 that I know of that is pinned this way.
It's a longer story and off topic, so I won't go into the details, but along with pinning the bolt, I changed the torque specs as I am not a fan of torque to yield when I can create a work around, which I did with the pin.
You will need to remove the bolt holding the steering shaft to the rack, both outer tie rod ends from the spindles, the 2 bolts holding in the rack, and 2 of the lines running into the rack from your pump, the other 2 lines run out and back into the rack so you wont need to remove them (I watched a video that said to remove all 4 but its not necessary. to get the rack out you will want to loosen the 4 bolts holding the cradle to the car, and lower it close to 3/4 of an inch to get the rack out, it will be impossible to do without doing this, don't try it its a waste of time. After doing it once it is really fairly easy after that, but is a tedious job that will make you curse.
Your balancer may have just went bad like many of the early C6 ones do, mine was wobbly and started to separate from the inner hub, its very common.
You may also want to get as tool that goes in place of your starter to hold your flexplate or pressure plate from turning when taking off and removing the balancer bolt, the compression of the engine is not enough to hold it still. I bought all the tools I needed pretty cheap online to do it myself.
Be careful not to let any of the 4 rubber bushings fall out of the rack that hold it in, I had one fall out and it turned into a clunking sound. I got lucky and the bushing was sitting on the cradle when I went to fix it so I didn't need a replacement but if this happens you have to do almost half the job over again to get the bushing back in.
I would upgrade to an aftermarket balancer, after seeing so many of the stock units fail I don't trust them and would hate to have to do the job again. I have seen people report having them go bad in as little as 15-20 thousand miles... I got a ProRace balancer, Summit badged and it is a nice unit, it is heavier than stock though if you care about that but its stainless and just a better unit., can be had from $190-230 depending on sales and supplier.
Best bet Drew, is to find a good independent Corvette shop (check with a local Corvette club for recommendations or post a query on your regional site here). As a reference, a Dealer may charge as much as $2000 for the job, while an independent will charge around $1200. Also, as others have noted, replace the OEM HB with an aftermarket....ATI & Powerbond are both good choices. Good luck & let us know how you make out.
Yeah, you keep thinking that way....
Are people really this small minded?? Tired of explaining it over and over.
Maybe another beer or two and it will come....
