Running ruff sometimes
Old Oct 8, 2017 | 10:29 PM
SFC-FF's Avatar
SFC-FF
4th Gear
Default Running ruff sometimes
I have a 2007 base model, at times it doesn't want too move goes into a stutter motion. Has this happen to anyone? Is this a fuel or transmission problem? Any help would be great. Also sometimes will not go into gear.Will go into gear after turning engine off a restarting engine.
Old Oct 8, 2017 | 10:44 PM
Patriot Six's Avatar
Patriot Six
Auto or manual?
Old Oct 9, 2017 | 02:21 AM
Dano523's Avatar
Dano523
Need more information, hence could just be a loose coil wire or you need to clean the MAF and air filters, to a more complex problem with the trans instead.
As for the not going into gear, if a manual transmission, then may be time to do a ranger clutch fluid change to get new flesh fluid into the clutch system.
Old Dec 16, 2017 | 05:53 PM
SFC-FF's Avatar
SFC-FF
4th Gear
Default Manual
Originally Posted by Patriot Six
Auto or manual?
It was the shift cables, replaced and running fine.
Old Dec 16, 2017 | 05:55 PM
SFC-FF's Avatar
SFC-FF
4th Gear
It was the shift cables, replaced and running fine. Thanks.
To Running ruff sometimes
