Octane Additive????
Old Nov 20, 2017 | 04:44 PM
partisan's Avatar
partisan
Default Octane Additive????
The price of 93 Octane is at least fifty cents higher per gallon than the 87 Octane. Each fill up is costing me $7.50 extra for the higher octane. Why wouldn't I be better off just to buy the 87 Octane and add a can of Octane boost with each fill up? The additive would give me more than the 93 I am getting from the pump. Just wondering if this idea would be harmful to my Z06? Thanks!
Old Nov 20, 2017 | 05:13 PM
doomi's Avatar
doomi
If I remember correctly each bottle of booster only boosts a tank of gas by like .1 octane or something like that. It's going to take a lot more than a bottle to get you to 93.
Old Nov 20, 2017 | 05:44 PM
partisan's Avatar
partisan
Old Nov 20, 2017 | 07:35 PM
Mordeth's Avatar
Mordeth
2018 C6 of Year Finalist
St. Jude Donor '10, '17
doomi is correct. The crap at the auto parts store only raises octane points, not octane numbers. So if it says one bottle increases a tank by 4 points, that means that 87 octane will go to 87.4 octane (and even this is questionable). If it were this easy and cheap to raise octane NUMBERS then we would all simply do it.
Now, there is race fuel concentrate like Torco or Boostane. This contains something called MMT which raises actual Octane numbers. One bottle of Boostane will raise octane legit by 7-10 numbers. However, it costs around $20/bottle. Therefore, to get from 87 to 93 it is still cheaper to simply fill up with 93. Torco or Boostane are used by guys that are stuck with 91 octane or someone needing to run 100+ octane due to high compression/boost.
Old Nov 20, 2017 | 10:37 PM
HOXXOH's Avatar
HOXXOH
The cost to raise 87 to 91 using Torco is roughly $1/gal. So paying $.50/gal to get 93 is a much better deal. I'd love to have your 93 "problem", since 91 is all we have in AZ. We can get 100 for around $10/gal to mix with 91, but that costs about $13/gal to just get to 95 when Torco will do it for $4/gal.
Old Nov 21, 2017 | 12:06 AM
mikeCsix's Avatar
mikeCsix
If you want to learn about octane an oil, a retired oil engineer on this forum has some quality posts. His name is LDB. It'll be worth your effort.
Old Nov 21, 2017 | 06:24 PM
partisan's Avatar
partisan
Thanks for all the info. I guess I'll keep buying the 93 octane and quit my bitchin'.
Old Nov 24, 2017 | 09:43 PM
buckmeister2's Avatar
buckmeister2
you will have to buy about 10 bottles to boost 6 points.
You DO NOT have to run premium! The manual "recommends" premium because that will give you the best performance. The car is built to operate cleanly and efficiently on regular unleaded. If you are not racing, and not pulling a trailer, you will be just fine.
I will not reply to anyone disputing this. It is not worth the time to argue a proven point.
Old Nov 25, 2017 | 10:39 AM
mikeCsix's Avatar
mikeCsix
Exactly why I don't like buying used cars...
Old Nov 25, 2017 | 10:58 AM
Mordeth's Avatar
Mordeth
Please ignore user buckmeister2, who is handing out poor advice. The car and engine (LS7) was designed to run on 91 or 93 octane (93 preferred). When you put in lower octane fuel two things happen:
1) The car reverts to a "low-octane" spark table in order to protect the motor. This reduces performance and the car will not operate as intended. Why would you intentionally reduce performance on a performance vehicle? All to save a few dollars? A ridiculous, absurd suggestion.
2) You run the risk of pre-ignition/detonation. A stupid, absurd risk, all to save a few dollars at the pump.
So in summary, ignore the poor advice of buckmeister2. You should be using 91 or 93 octane in your car, with 93 as the preferred, recommended option.
Old Nov 25, 2017 | 11:36 AM
mikeCsix's Avatar
mikeCsix
Agreed, in the past, I've torn down too many engines and saw the damaged piston as a result of detonation. For modern day cars, I don't believe the anti-knock systems are quick enough to avoid at least some detonation before it can pull timing. The bigger question is why spend upwards of 50k bucks on a car and go cheap on the proper fuel? If I screw up and find I have no options but to use regular fuel, that's one thing. But on a regular basis is simply retarded. Heck, I'm sure people that will do this will also run recycled oil too, and the complain about cheap gm products not holding up.
Old Nov 25, 2017 | 01:02 PM
Chiselchst's Avatar
Chiselchst
The difference would be the higher octane pump gas is reformed or upgraded by changing the molecular structure (more reformate, platformate, rheniformed product, etc. blended in). The additives that work use MMT (Torco, BOOSTane, etc), which does work (more than a few points as previously stated in some posts above), but are not "OK'ed" by most automakers in the US (or the EPA, etc.) due to the orange tinge left from combustion. Deposits are also left on the various sensors, etc. It's commonly used in CAN though...
Refining for octane; Reforming, or rheniforming, changes the octane by stripping an H2 bond, creating double bonds on the HC atoms, thus increasing the octane (much preferred) (on straight run naphthas). Isomeration, or the alky process in refining also makes some even better killer premo octane components...leaving the additive requirements to focus on deposit reduction, etc.
Old Nov 25, 2017 | 05:22 PM
buckmeister2
My apologies to all involved. I did not realize it was a Z06. I re-read the post, and there it is, at the very end. My bad....
Old Nov 25, 2017 | 06:45 PM
fisher auto's Avatar
fisher auto
No offense we are not driving a civic......
Old Nov 25, 2017 | 06:58 PM
Dcasole's Avatar
Dcasole
I still would not do it with my LS3 ... like said above , I bought a Corvette , a performance car, that runs better on premium ... I will leave the regular gas for my Taurus....
Dave
Old Nov 26, 2017 | 10:13 AM
partisan's Avatar
partisan
Old Nov 26, 2017 | 06:09 PM
mikeCsix's Avatar
mikeCsix
No offense taken Buckmeister!
Old Nov 28, 2017 | 01:09 AM
Dano523's Avatar
Dano523
Same higher octane rating allow applies to the LS2 motor as well (wants 93 octane to due to the higher compression).
It was the LS3 motor that had the compression dropped to run better on 91 octane instead.
To Octane Additive????
