Plug wire insulators
Old Nov 26, 2017 | 09:59 PM
Fly N Low's Avatar
Fly N Low
Default Plug wire insulators
I am getting ready to install ARH headers on my 05. Was considering using spark plug wire (sock type) insulators on the wires and boots. Anyone used these... Thoughts!!!
Old Nov 26, 2017 | 10:08 PM
CMY SIX's Avatar
CMY SIX
they work
Old Nov 27, 2017 | 09:53 AM
Kenny94945's Avatar
Kenny94945
Yes, use them and they work.
Kool Sox sleeves I believe is brand I have.
IMO Don't even research whether to use them or not....yes use them.
Old Nov 27, 2017 | 03:06 PM
Must_Have_Z's Avatar
Must_Have_Z
It depends. If your wires are close to the header, even insulators/socks won't help. It will burn through them. You need to get wires that clear your headers, period. An air gap of at least a few millimeters is required between your wire and the header, and then you will have no issues. The same goes for an insulator sock if you put them on. If you don't have an air gap, they're gonna burn. If it was me, I'd skip the socks and just get a good wire that provides an air gap. That's what I've done on my C6Z with Kooks headers and never have a problem.
Old Nov 27, 2017 | 07:42 PM
Adrian @ F.A.S.T.'s Avatar
0Adrian @ F.A.S.T.
Former Vendor
http://fastautoracing.com/store/spar...vette-set-of-8
Always use them with headers, we like to use Taylor Thunder wires with those (part #98003) .
Old Nov 27, 2017 | 09:24 PM
HK770's Avatar
HK770
Work well for me!
Old Nov 27, 2017 | 09:58 PM
myredhead1's Avatar
myredhead1
Absolutely get a set. Best $30-40 insurance out there.
Don't forget to keep your O2 extensions safe as well.
Old Nov 28, 2017 | 10:12 AM
Must_Have_Z
If you don't make sure there's clearance between your wire/boot and the header first, the insulators won't help.
Old Nov 28, 2017 | 10:21 AM
BLKTA's Avatar
BLKTA
I run 2" headers on my setup and kept burning the plug wire on #2 so I switched the Accel Ceramic boot wires and it's been fine ever since. $$$ but worth it in my case.
To Plug wire insulators
