Prop shaft rebuild.....?
Old Jan 10, 2018 | 09:29 PM
rabrooks's Avatar
rabrooks
LOL, all that for nothing..............So to speak.
Good for the rest of us
Old Jan 11, 2018 | 12:02 AM
C U IN REARVEIW's Avatar
C U IN REARVEIW
Why do you say that? torque tube was already out of the car for clutch install....plus I am replacing couplers,just not bearings. Not like it's that much more work once your in that far....
Old Jan 11, 2018 | 03:01 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Might as well have checked them while it was apart IMO (like you did)
Old Jan 11, 2018 | 03:16 PM
C U IN REARVEIW
The guys at RPM said I should probably change them even though car has low miles....they said cars that sit alot have a tendency to put excessive amount of wear on the bottom ball bearing and cause premature bearing failure
Old Jan 11, 2018 | 03:19 PM
C U IN REARVEIW
Are you still running oem propshaft setup? Thinking I will be in your power range after this swap (t-trim/3.4" pulley)
Old Jan 11, 2018 | 03:56 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Yeah, stock one is still in there. But I'm still on '05 rear end so I can't really do hard launches or anything like that, mostly 2nd gear and up for me
Old Jan 11, 2018 | 05:37 PM
C U IN REARVEIW
Never rebuilt propshaft? Your high in miles too huh?
Old Jan 11, 2018 | 09:57 PM
racer151's Avatar
racer151
Dose anybody know rather the large locking nut that is on the back of the shaft is reusable or a remove and replace? I took it off so I can get to the bearings and it came off really hard. Threads look ok but not perfect...
Old Jan 11, 2018 | 10:19 PM
MARSC6's Avatar
MARSC6
I had to replace those bearings in a 12k mile 06 last year. Its a ridiculous amount of work I had to do a second time for not replacing them when I did the clutch.
Old Jan 11, 2018 | 11:34 PM
C U IN REARVEIW
That's my fear
Old Jan 12, 2018 | 09:35 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I'm at like 200K now
I replaced the couplers, bolts, bearings and bearing slinger or whatever it's called that goes in front of the first bearing not long after I bought it at like 130K or so
Old May 24, 2018 | 08:41 AM
Dale002's Avatar
Dale002
Do you remember where you purchased the slinger from and or the part number. I'm having issues finding it and mine got al little damaged on removal.
Old May 24, 2018 | 08:55 AM
  #33
schpenxel's Avatar
schpenxel
St. Jude Donor '15
RPM overnighted me one. Wasn't cheap but I needed it and they had it
Old May 24, 2018 | 11:26 AM
  #34
jeremysz's Avatar
jeremysz
Here is the part number on the slinger. I’m in the process of doing bearings and a carbon fiber shaft.
