Header heat shielding
I understand header wraps may have a detrimental effect on the header itself. How bad the effect, I cant seem to find any trustworthy information. Just a lot of "i heard someone say that someones headers rusted out..." with no info on if it was mild, stainless, etc.
Looking at the properties of 304SS, I have read that it doesnt like cooling slowly due to carbide precipitation (grain structure change). I can see how having a wrap on it may allow these carbide crystals to form, ultimately causing failure. However, Annealing temps are at ~1900F so i think that is unlikely to occur if I am not running the car hard on a track. If I gain access to an IR thermometer I will check the temp after driving it hard.
I have found a few posts about header wrap soaking with oil and causing a fire.
I am not sure if that not having the header wrap would have helped it in any way - enough oil on hot headers will flash. Still, I CAN see the is possible that the wrap would act like a wick in oil lamps, feeding a fire. Again, oil wicks do need to be SOAKED in oil though, and that is going to cause a fire regardless of whether that wrap was there or not. I guess its possible the wrap will remain ablaze longer since the oil cant be evaporated/flashed off as quickly as a naked header.
Again, I was looking mainly at lines that could possibly use shielding from radiant heat... I do appreciate concerns from people saying "just get it coated."
I will update the thread if i burn the car down due to the header wrap. I will update the thread if my headers fall apart due to corrosion/??.
And I will update with what lines I insulated while doing the swap for anyone who may want to insulate them as well (whether they wrap the headers or not).
Still, these would probably all cause a fire whether the wrap was on there or not so idk if its really a header wrap con.
the gains that you think you are going to get by increased scavaging...? Really ... show me the data on what the gains are ....
I have been around a long time and never has increasing the velocity of exhaust gas by wrapping headers ever shown to produce gains ...
Other modifications such as the design of the collector etc will increase the cylinder scavaging....but not wrapping or coating coating the headers ....
Also please show me the data on lowering in temps... I am dieing to see this information
And please ..Not someone feels like the temps are reduced ... show me real data
You are not running a pro stocker or a road race car ... by God you are running a street car , how much heat you think you are going to produce ...
I did measure the temps around my starter at several points and with uncoated headers the temps were actually lower ....
that cast stock iron manifold with a hot cat radiating much more heat than my stainless steel LG's do .....
Just use common sense , wire tie the clutch hose and any wires so they stay safely away ,heck u dont even need the spark plug socks if you take your time and angle the wires correctly
You do what you have to do...but I am telling you u are wasting your time ..
Dave
Remember that insulating materials work both ways. i.e. if you insulate the starter, you both reduce the heat transfer rate into it, as well as reduce the heat transfer out of it. think of an oven; if you shut the oven off, it stays hot longer with the door shut.
Dave
Thermodynamics. I will guarantee you that the headers will get the under hood materials hotter. Headers WILL be hotter than cast manifold at the surface, and radiation is a function of surface temperature.
I am NOT joking. I was simply asking anyone who has installed their own set of headers what wires and materials were near it.
I understand (as I CONSTANTLY mentioned) that header wrap COULD hurt the headers themselves. I did look up 304SS's acceptable intermittent temperature (which is 1600F, continuous @ 2000F) and I believe its within tolerance of most NON-FI EGTs. I also mentioned I would measure when I did wrap it.
If the headers are higher than 1600F then I planned on unwrapping them because -surprise- I am not an idiot.
Just FYI, common sense is not very common. If you can show me that wrapping headers IS a problem, in any other respect than what I mentioned please let me know instead of just parroting other posters.
It will cost me $60 of header wrap and maybe 2-3 hours of my time to wrap. Maybe another $50 in wire loom wrap and $25 for a starter blanket.
So for less than $150, if I have lowered under hood heat and (look this up if you dont believe me) electronics and plastic damage due to said heat, it is worth it.
As for why it will heat up more with headers?
EGT (same temp regardless, assuming same power/performance level) -thin stainless tube->outside air
EGT - THICK stock manifold -> outside air
Simple convection -> conduction ->radiation experiment.
Even if the convection is the same for mani or headers, the thickness of a stock header manifold appears to be 1/4" to 3/8" compared to a 16 or 18 gauge header pipe thickness. What do you think will be hotter to the touch?
headers-WILL-create a hotter underhood temp. However, manifolds will remain hot longer due to their thermal mass.
Why your starter was hotter with stock manifolds, I have no idea. Possibly, the cat is radiating far more heat than the headers at the time. If you were to drive it hard and measure temps immediately I suspect a very different scenario. I believe a cat's operating temperature is (from google searching) 400 to 1200F so if your cats were on the way out, it could definitely have been radiating much more heat. They are also designed to heat up quickly so if you drove the car for both measurements for too short of a period, the cats would be fully heated up while the headers would not...
Well - sort of. Its the GS model so I have the small NACA-esque duct that allows cold air into the airbox location. Not quite as large as a vararam or vettescoop but similar in result. I have the entire air box insulated and I am looking to make something similar to the halltech beehive to hide the filter from under hood air. I would prefer to swap intakes for a larger bridge but I do like the OEM filtration. Still, I think the larger bridge is mainly unnecessary for me since the Z06 with much more HP uses the same intake size.
I had a K&N on my previous vehicle and that rotted out the cotton filter media so if I did go to a true CAI, I would go with the MAF forward halltech with some dry flow filter. Not sure why GM put the MAF/AIT right on top of the radiator. I actually monitor my IATs constantly (Dashcommand!). As long as I am +45 mph, my IATs are +5F of ambient or less. When it heat soaks while sitting at a light, it takes roughly 1 min before the IATs drop. Not TOO bad. Im definitely looking at how to insulate my MAF/IAT from the radiator as well.
Am I looking for 1K HP? Not currently. I just want my car to be extremely well maintained. I have way too much experience with old GM cars (4th gen camaro, 3rd gen formula firebird, 3rd gen camaro, etc...) and know how CRAP the plastics they use are to put too much trust in it.
I plan on leaving a small section of the header primary entry exposed so i can take temps of the hottest location. I think that would also be a good physical break for oil which may leak from the valve cover which I am most worried about. Header failure is not a huge concern because if it fails, ill just go back to stock...
I purchased an IR thermometer to check temp difference between manis and headers. On a normal drive, the outside of my manifolds would be about 200C. With these WRAPPED headers, its now about 500C. So for everyone stating "its no different" - theres a HUGE difference. The plastic pieces around the engine bay which used to be cool enough to touch are now way too hot to touch after a drive.
On to the important stuff:
I wrapped: Starter, AC lines, clutch line, oil cooler lines and o2 lines. thats it!
Also are you sure it was 500c u measured , that 900 F hmmmmmm that's pretty hot
Coating is ok,but wrapped headers look like ****...I've only seen wrap on Rat Rods.
