Brake Replacement Question
Old Jan 26, 2018 | 08:58 AM
geezel's Avatar
geezel
Default Brake Replacement Question
The new GM front brake rotors I received for my 2007 Z06 are 100% prime painted including the contact surfaces at the brake pads. Do I need to remove the primer at the contact surfaces, or does the initial braking process take care of that?
Old Jan 26, 2018 | 09:02 AM
timd38's Avatar
timd38
Paint will be off after one or 2 stops.
Old Jan 26, 2018 | 09:41 AM
geezel's Avatar
geezel
OK. Thanks.
Old Jan 26, 2018 | 04:41 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
Mine were the same....first couple of stops scrubs off the coating. However, before you mount the rotors, you should wipe down the braking surfaces (front & back) with brake cleaner to get rid of any oil or contaminants from the manufacturing process on the surfaces.
Old Jan 26, 2018 | 08:53 PM
Sayfoo's Avatar
Sayfoo
I would clean it off. Lacquer thinner? A light sanding?
I know it will wear off, but where does it go?
Will it contaminate your pads?
Old Jan 26, 2018 | 10:09 PM
geezel's Avatar
geezel
I guess I'll remove it.
Old Jan 26, 2018 | 11:08 PM
HOXXOH's Avatar
HOXXOH
When I plated my rotors, I put the old pads on. Then drove it a bit to wipe off the plating in the swept area, before putting the new pads on. The old pads then went in the trash along with the zinc plating.
It was an extra step, but got no crap on the new pads.
Old Feb 5, 2018 | 11:26 AM
itomh's Avatar
itomh
I would not be concerned, braking will clean it off. Another poster recommended cleaning them off first and let the old pads clean them up and toss old pads away due to pad contamination. If that's the case, what happens to all the road grime that gets on pads from just daily driving? Wait......Does that mean my new pads are now contaminated? Now I have 4 cars I have to redo!!
To Brake Replacement Question
