Does anyone know if the z51/z06 front spring will improve handling on a base model? I already have Michelin PSS, Z06 bars and Bilstein Sports. Or is my current setup better?
The front spring sets up the amount of dive under braking conditions for weight transfer, and truth be told, if you don't have enough tire grip to start with running the Z06 sways with the base front spring, could end up with the car have a great deal more under steering with the Fe3 spring instead.
Hence on a narrow body car, really need to be running R8's in narrow body size tires, to get close to a Z06 suspension to working correctly on it to begin with.
Just throwing parts on the car without study and the ability to tune is wasting time and money. I would get a good book on suspension tuning before going any further. These cars have a lot of horsepower and a poorly tuned suspension can lead to disaster if not done correctly.
Tires are your biggest determinant for traction, dampers and sway bars are fine tuning devices, the springs are coarse tuning devices. Once the tires are figured out, springs are next, then sways and dampers. The Z-06 sways (and ZR-1) are for the bigger street tires, using them with base tire sizes can lead to unpredictable results, introducing more over or under steer conditions. Unless you have a track and a really good driver that can tell the difference (and maybe you do and are), the results will be unpredictable.
Somebody with a lot of experience is worth talking to, Sam Strano is one such person. LG motorsports may be another.
Maybe you've already done so but didn't articulate, but what are your goals? What are you trying to design to? Then call some experts and seek their opinions, then test.
Since the rear springs are almost identical of the base and z51 , swapping a front z51 spring will have a similar setup as the z51, but I was wondering if it's better or worse than to keep the base front spring (along with the Z06 sways and Bilstein Sports). High speed stability is important as I live near the German Autobahn
Bilsteins are a fantastic upgrade over OE shocks. I think the Z51 or the Z06 front spring would also be an improvement. In my opinion, you have way too much rear sway bar on that car. Swap it out for a Z51 bar and you'll be real close to a Z51 equipped C6.
I agree with the others, the Z51 package handled pretty good so I would go Z51 springs and sways, front and rear, since you've already swapped the shocks. The Z51 shocks were fairly stiff too, so that might be analternative if the shocks you have don't work well. I've tracked this setup snd had good stability at 140mph. You may also want the Z51 brakes too.
Think about the fact that the C6Z comes with too much rear bar to begin with IMO...stock C6Z's exhibit plenty of oversteer.
You have that wrong a stock Z will push in the corners. The factory builds understeer in for low performance drivers. You are inducing corner exit oversteer with the throttle.
And what makes the C6 Z51 cars don't do quite well in the slalom test (same slalom speed as old Mustang GT)? Is it that they have more understeer than the Z06/GS? Tires? Is it the spring setup balance (less difference in rate front to back than the Z06? I don't want to create more understeer by swapping a front z51 spring. My C6 drives very well except for a little body roll on the Ring before my Bilsteins when I still had the C6z06 shocks. I also heard that the Z06 gets out of balance pretty easily with bumps in the road? Does the Z06 have too stiff springs for the street, the famous leafspring crosstalk? I want the best setup for handling mainly for the street.
Put it in and try it, you dont like it, take it out.
Not that hard to change.
Anytime you go stiffer in spring rate the ride will be harsher. In my opinion I would get a T1 front spring with a Z06 rear spring. Sway bars would be a strano 32mm adjustable with a stock z06 rear bar. Tune for balance with the front bar if that isn't enough go with the strano adjustable rear bar. I would also go with a min of koni sports for shocks. Get as big of a rim/tire combination that will fit and set the alignment on kill.
Are you talking C6Z? C6Z's are set up with a much stiffer rear bar...which almost always translates to oversteer. In the C6Z's case, its even susceptible to snap oversteer as well if you don't work the throttle right. IMO, GM should've added more front bar to the C6Z. I've often contemplated swapping in a ZR1 bar, just to get a little more bar up front (for not a lot of money) while using OE parts.
C5Z's had a much more balanced/neutral feel (used to own a C5Z)...and note the C5Z sway bar bias front to rear (on the chart) versus the C6Z (or ZR1 for that matter).
Look at GM T1 bars or even the JOC bars. Even with the adjustable rear bars, you cant dial in more (rear) bar than the front for either set. Not a Pfadt fan, but their sway bar graph is always useful...
Now for the OP's situation...running a C6Z rear bar with base C6 width rear tires (assuming this to be the case) will definitely overpower his tires when hard cornering/pushing the limits.
