Which header for LS2
Old Apr 6, 2018 | 05:52 AM
Suns_PSD's Avatar
Suns_PSD
If you keeping the LS2 heads, even ported, run a 1.75" header. It will make more power everywhere on the LS2 than the 1 7/8" header.
Good luck!
Old Apr 6, 2018 | 11:23 PM
Cherokee Nation's Avatar
Cherokee Nation
Originally Posted by Ahrmike
Ohh. They probably did too much inner porting after they welded the tube. If its a really thin break in the weld the carbon might seal up the holes enough so they arent leaking anymore. Or, if they only leak at WOT it might not matter since the car goes into open loop anyway and ignores the O2s.
That is prtty terrible that ARH won't honor it though. I can understand a defect since i believe the porting is done by hand after its welded, but they should stand by their products.
I think you can see that they are leaking on the underside also,,,(All Eight Are Like This One) Strange Huh.....ARH has very poor quality control...You think.
Old Apr 7, 2018 | 12:29 PM
YLOFEVR's Avatar
YLOFEVR
St. Jude Donor '09-'10-'11
Default C6 Headers
I've had LG Long Tubes with hi-flow cats and am very happy with them--no problems with install, fitment or performance.
Old Apr 7, 2018 | 06:40 PM
davidfarmer's Avatar
davidfarmer
$155 on the auction site....fits great, SS, TIG welded, all O2 extensions and hardware included. Stolen from another design, but every long tube design was stolen from W2W which is no longer around
Old Apr 7, 2018 | 07:48 PM
Andysherman's Avatar
Andysherman
I have ARH 1.75's with their catted x-pipe on my 07... unfortunate about the other posts to the contrary, but mine went on & fit like a dream, tucked up extremely nicely in the tunnel, with the rear O2 sensors slanted in a very well-thought out fashion (& I'm an engineer). Flange seals are good, & this guy is EXTREMELY happy that I went the extra expense for the excellent fit & finish.
Old Apr 8, 2018 | 02:34 AM
xerox17's Avatar
xerox17
I went with hinson ceramic coated headers and noncatted xpipe and they fit great no leaks
Old Apr 12, 2018 | 02:16 PM
Joe Link's Avatar
Joe Link
Which brand? Got a link?
Old Apr 12, 2018 | 10:12 PM
da6speed's Avatar
da6speed
1-7/8 ARH here. No leaks. Fit great. Easy install. No regrets. And did not interfere with trans cooler lines. Oem gaskets and a/m bolts.
Old Apr 19, 2018 | 11:02 PM
Joe Link's Avatar
Joe Link
I was all set to pull the trigger on a set of OBX headers, but I was nervous due to a few of the negative threads I saw here and elsewhere (overall reviews do seem positive though).
I read the fine print and the eBay ads for everyone selling the OBX package stipulated that the buyer was responsible for covering shipping both ways and a 25% restocking fee, no matter what. This didn't sit well with me, as I know I'd be mad if I got a crappy set and had to pay a couple hundred for them to fix an issue which was in no way my fault.
I decided to check out Maryland Speed, who made me a great deal on Kook's for my CTS-V. They're running a couple package deals on Kook's and Halltech or Vararam intakes which I was considering. Then a chat window pops up and....we'll just say they made me an offer I couldn't refuse
Yeah, my wallet is quite a bit lighter, but I'll sleep better knowing I have quality parts on my vehicle and that I have two great companies backing me up should a problem arise.
Old Apr 20, 2018 | 06:20 AM
Dcasole's Avatar
Dcasole
I hope you get them , there has been more than one complaint about that vendor, do a search
https://www.corvetteforum.com/forums...-5-months.html
Dave
Old Apr 20, 2018 | 08:44 AM
irok's Avatar
irok
the OBX are a quality part with perfect fit and finish that will make the same power as anything out there.100 % tig welded all the way around header pipe on flanges so you won't have leaks.have had on my car for 7 years with no issues
Old Apr 20, 2018 | 05:11 PM
davidfarmer
the ones I bought are out of stock but they told me they are expecting more. The seller is "awesomecarparts"
Mine fit extremely well, and came with clamps and o2 extensions.
Old Apr 22, 2018 | 03:36 AM
  #33
sabastian458's Avatar
sabastian458
Personal experience with my C5 with ls2 swap. Originally has LG 1 3/4 castles and car felt good, but the lower primaries had accumulated some damage, one was 1/2 flat. So I went with one of the cheaper options for LTs in 1 3/4, and found that the LT lengths to be a fair amount shorter, also the car felt bottle necked. Immediately removed and installed a set of Stainless Works 1 7/8 and the car was better than ever. If I had to do it again I would go 1 7/8 or 2 inch primaries.
220 TFS, FAST 92, vindicator cam, 60lb injectors and a Vararam. Good for 471hp on a conservative tune. Same setup but in a GTO and different tune netted 439.
Old Apr 23, 2018 | 10:55 AM
  #34
Joe Link's Avatar
Joe Link
Dave
Damn, so do I. Thanks for the heads up.
Old Apr 24, 2018 | 03:53 PM
  #35
Neumonic2002's Avatar
Neumonic2002
I ran 1 3/4 ARH W/High Flow cats on mt 06 LS2, install was easy and never had an issue with any leaks.
Car also had Trick Flow As Cast 220's, Yella Terra Rockers, 235/239 Comp Cam, Fast 102 intake, ported TB and a Vararam and put down 503/447
I have installed Kook's on several cars, I like them as well.
