How to pull your engine in 45 easy steps
You’ll also need to remove the little rubber hose connected to the valley cover (the other end would have been removed when you took off the intake manifold):
There is a total of four 15mm bolts that need to be removed as shown in the next three pictures. One of them comes out completely and the other three need to be unscrewed enough so that the bracket can be pulled away from the engine as shown in the final picture. It’s a slow and annoying process as some of the bolts can only be turned a partial revolution each time before having to readjust the wrench.
Showing the bracket pulled away from the head:
Remove the coolant temperature sensor located on the driver side head towards the front:
Showing the exhaust after it’s been unbolted from the heads:
If your car is a wet sump then there’ll be an additional step of removing the dipstick bracket in order to access the center exhaust manifold bolts on the passenger side.
Remove the 15mm bolt, pull the bracket off as well as remove the dipstick and then you’ll have access to the exhaust manifold bolts:
Showing the passenger side after the headers have been disconnected:
Placement of the floor jack under the center of the cradle:
Car sitting on two jackstands:
The rear shock bolt:
The front shock bolt:
The first step is to jack up the shock and control arm front underneath to take pressure off the upper control arm which makes removing the bolts much easier. I usually jack it up enough such that I can see the frame of the car start to lift up off the jackstand(s):
Use a 13mm deep socket and 13mm open end wrench to remove each of the two shock bolts:
What the assembly looks like after everything’s been disconnected:
Hopefully your tunnel plate won’t be as dirty as mine, which is a result of a rear main seal leak. At this point you’ll need to have removed the rest of your exhaust if you haven’t done so yet. I’m running open headers which is why I don’t have any pictures of the exhaust installed.
Rear of the tunnel plate:
Towards the front:
Showing the torque tube after the tunnel plate has been removed:
The two arrows pointing to the starter bolts are actually for the next step.
Next is the tan colored connector which can be extremely brittle if you’ve been running headers:
Showing the connector after it’s been removed:
The knock sensor is attached with a 13mm bolt:
In order to not lose the bolt I just screw it back in:
Front:
Rear passenger side:
Rear driver side:
Driver side:
Passenger side:
If you’ve got either a Z51 or Z06 then you’ll most likely need to unbolt the front sway bar in order to access the two front cradle bolts. I no longer have a sway bar so I couldn’t show you how it’s connected but it’s pretty straightforward.
Passenger side front:
Passenger side rear:
Driver side front:
Driver side rear:
Once all four bolts have been removed slowly start to lower the transmission jack. I suggest doing it in very small increments to make sure it’s not caught up on anything. It usually will drop down fairly easily unless you’ve forgotten to disconnect something. If you see one side coming down but not the other, this is usually just a case of not bringing it down evenly and jacking it up and starting again usually fixes the problem. Under no circumstances though should you ever have to pry it apart from the frame.
The next few pictures show what the cradle looks like after having been lowered, from various angles underneath the car:
The logic behind this is twofold – one, it ends up giving you additional room to gain access to the bellhousing and upper torque tube bolts and two, it makes separating the torque tube from the bellhousing much easier (as well as reinstalling it later one).
You do however have to be very careful though depending on what brand of leveler you’re using and how long the boom of the engine hoist is. As shown in the following picture you can see how close the back of the leveler is to coming in contact with the cowl. If you start lowering the motor without checking the clearance it’s extremely easy to damage and/or break the cowl.
I had the very same issue when I pulled the motor this time because when I started, the large nut on the leveler was sitting directly on top of the cowl. What I ended up doing was supporting the motor from underneath with my large floor jack, lowering it so that the leveler was below the cowl and then tightening up the tension on the engine hoist again.
A little more...
And right where we need it, which will be level to the ground:
If you’ve got a manual car then the driveshaft simply slides into the back of the flywheel so no additional work will be necessary once you start to separate the torque tube from the bellhousing.
Driver side:
Passenger side:
