Changing Calipers
Old May 3, 2018 | 06:54 PM
RobJoy's Avatar
RobJoy
Default Changing Calipers
If I replace my calipers and lose only a minimal amount of fluid by using rubber stop plugs on the steel line while I'm making the swap, will I have to have the ABS reprogrammed? I think I'm asking the right question here. That is, will swapping the calipers require any other action besides just swapping the calipers? Of course I'll be swapping the hoses, rotors, pads.
Of course, I do know to keep an eye on the master cylinder reservoir to make sure it doesn't run dry. And, I'll be using the gravity method to fill each caliper and then a handheld vacuum pump to pull out any remaining bubbles.
Old May 3, 2018 | 07:03 PM
xBoostx's Avatar
xBoostx
All I do is bleed the brakes never had a problem IMO don't mess with the abs.
Old May 3, 2018 | 08:00 PM
05 Wreck's Avatar
05 Wreck
Just put new Wilwood's on the rear. Second time I've changed calipers. Pressure bled both times, never had a problem.
Old May 4, 2018 | 04:07 AM
Dano523's Avatar
Dano523
The problem is when the system goes dry, you end up with Air in the ABS pump, and then need to use a Tech II to cycle the pump to get the air out of it.
Old May 4, 2018 | 01:40 PM
RobJoy's Avatar
RobJoy
Default Watchful eye
I'll definitely have to keep an eye on the master cylinder reservoir while swapping out each caliper. Definitely don't want to be going to all that pricey Tech II stuff because I wasn't paying attention to that.
Old May 5, 2018 | 11:07 AM
Dano523's Avatar
Dano523
Wouldn't say pricey stuff, since a VX Gm nano goes for around $100 if you have a windows 7 machine to run it's Tech2win software, or a Tech II clone goes for about $250 instead.
Hence if you are going to wrench on a C6, at some point your going to need a tech II, if not just for calibrating a new brake pedal sensor on its replacement.
https://www.corvetteforum.com/forums...ternative.html
Old May 5, 2018 | 06:49 PM
torquetube's Avatar
torquetube
I've changed calipers eight times, and I have a Tech 2, and I've never needed it to recover a rock-solid pedal. You'll be fine.
Old May 6, 2018 | 02:00 PM
victorf's Avatar
victorf
^^same here, although not eight times with my caliper but unable to finish brake job and did left the brake line plugged over night.
I too have a Tech 2.
To Changing Calipers
