Steering rack sensor
Old Jun 2, 2018 | 03:44 PM
tdishon's Avatar
tdishon
Default Steering rack sensor
I am using a 2012 GS donor chassis for my 59 Chevy Apache. before I clip off the two wire sensor on the steering rack, I was wondering what it was for? Pressure or temp maybe?
Old Jun 3, 2018 | 03:48 AM
Dano523's Avatar
Dano523
https://www.corvetteforum.com/forums...-question.html
Old Jun 3, 2018 | 01:58 PM
tdishon's Avatar
tdishon
I read the post and didn't understand. Is this a "magnasteer"?
Old Jun 3, 2018 | 05:37 PM
Dano523's Avatar
Dano523
Originally Posted by tdishon
I read the post and didn't understand. Is this a "magnasteer?
Yep, and the EBCM is what controls the magnasteer in the rack.
So on a C6 EBCM, you have the wheel speed senors from each wheel bearing, the steering wheel position sensor, the yaw/accelerator, and a few other systems/modules that the Ebcm is motoring for not only the magnasteer, the ABS system, TC, but active handling as well.
If your not planning on using the EBCM/its systems, then need to pull the magnasteer rack and install a manual rack isntead.
https://www.poormanmotorsports.com/p...z-k-member-kit
Old Jun 3, 2018 | 05:44 PM
steering_experts1's Avatar
0steering_experts1
Former Vendor
You can still use the magnasteer rack without the electronics, however you will have the steering effort of the C6 at 45mph.
Thanks,
Junior
Turn One
Old Jun 3, 2018 | 08:30 PM
tdishon's Avatar
tdishon
I am using power steering and a hydroboost, but not the magnasteer wiring. What is the steering effort of a c6 at 45mph?
Does that mean it's much softer or harder? I just want a consistent feel.
Old Jun 5, 2018 | 08:47 AM
0steering_experts1
Former Vendor
It will have a lighter feel to it, but in a different application it may feel great. I would recommend trying it and if it needs to be heavier or lighter then we can modify the flow rate of the pump to fine tune the feel.
Thanks,
Junior
To Steering rack sensor
