2008 TPMS problems, help please
Old Jun 15, 2018 | 07:28 AM
Killermullet's Avatar
Killermullet
Default 2008 TPMS problems, help please
I just picked up a 2008 Vert (my 3rd 2008, guess I should stop selling them!). I got a good deal partially because the TPMS service warning is on and the light is solid on.
Only the LF tire displays "XX" and the other three display nothing.
I've read numerous threads and attempted reprogramming using a VXDAS EL-50448 tool I bought cheap on Amazon. The car goes into learn mode but there is no response to programming.
I've read that "XX" means the module isn't seeing the sensors. What does it mean when there is no display at all, no pressure and no "XX"?
Suggested troubleshooting from here? I have no idea if the cheap tool is working so I was thinking I'd try a tire place and see if a better tool does anything.
Old Jun 15, 2018 | 08:30 AM
Sphurley's Avatar
Sphurley
There are better tools that a real tire shop will have. I can tell the serial number, batter level, and air pressure with mine. If they can't see them with their tool then the batteries are all dead.
I ended up with the tool when trying to troubleshoot my XX problem.
I narrowed it down to the receiver, bought one, and in the process of removing the radio to get to it I found a blue tooth adapter the previous owner had installed the was causing the issue. Removed it and no more problems.
Old Jun 15, 2018 | 09:33 AM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
Sounds like the battery is gone in the sensor and needs to be replace.
I have the same type of learning tool and it works fine.
The car is 10 years old. Could be the sensors are the same age and could all need to be replace.
Just a thought.
Old Jun 15, 2018 | 08:21 PM
Dad3Sons's Avatar
Dad3Sons
I have a 2006 vert. Was traveling for a couple of weeks. When I got home the Vette battery went flat from sitting in the garage. After an overnight charge at 2A, the car fired right up but the “Service Tire Monitor” warning comes on at startup in the DIC. I get “XX” on 3 of the tires, and nothing in the RT Rear indicator.
Is there a “reboot” process for the TPMS system?
Thanks!!
Old Jun 15, 2018 | 08:31 PM
Sphurley's Avatar
Sphurley
Thanks!!
TPMS sensors go to sleep to conserve battery life. They wake up when the tires are moving or when probed by a tester.
Try driving it.
Old Jun 15, 2018 | 09:00 PM
Dad3Sons's Avatar
Dad3Sons
I guess I left out that critical piece of info. I’ve driven it about 200 miles since the battery charge. I also had to re-index the windows so the power top would work. Discovered that issue after a previous battery fade out.
Old Jun 15, 2018 | 09:38 PM
Sphurley's Avatar
Sphurley
How old are the sensors? My 2010 didn't make it 7years. (not many miles)
Old Jun 15, 2018 | 10:47 PM
ptroxx's Avatar
ptroxx
Same for my 2010 GS. I got it in Jan 2016 and the day after I picked the car up sight unseen. Had a friend check it out for me. But one sensor went out on me. Replace it. Then on the way back to Cali another one ent. Lol. So needless to say I changed them later that year when I swapped wheels.
Old Jun 15, 2018 | 11:02 PM
Dad3Sons's Avatar
Dad3Sons
I’ve only had the car since January and it has 81K miles. Before the battery faded, the TPMS worked reliably, but I’d get a RT Rear tire flat warning occasionally. Probably take it to the tire shop this weekend and have them put the diagnostic tool on it. The tire sensors are probably original....
Old Jun 16, 2018 | 03:23 AM
Dano523's Avatar
Dano523
TPMS's are stand alone units in the tire, so all that is needed is just a TPMS tool that can trigger the senor to get a reading from each TPMS one at a time isntead.
Attachment 48333004
If the reading comes back at either will not trigger, or the battery is weak, then the the TPMS is replaced in the tire, and relearned to the cars RCDLR.
Myself, would pick up a set of OEM tpms's (gm #25758220) since their batteries last about the longest , then have all 4 TPMS replaced in the tires as a set. Hence if one of the sensors batteries is dying, then figure that the rest of the sensor batteries will be dying shortly afterwards.
Hence if the problem is a RCDLR problem with the TPMS just needing to be relearned to the car due to a gltich in the RCDLR, you get the 00 read out in the DIC.
Note, if you disconnect the battery, and have not driving the car for a few miles so the RCDLR can pull another reading from the TPMS's, will get the 00 reading in the DIC as well.
When the TPMS battery dies, then you get the XX reading in the DIC instead.
Old Jun 17, 2018 | 11:32 AM
73DBG's Avatar
73DBG
I didn’t have XX on pressure but a few weeks ago I had my left rear tire constantly reading 50psi, just the left. It did not have 50psi. Tried to reset by disconnecting the battery but it still read 50psi. Never did get it to a place with the reset tool. I can’t prove this for 100% but when I started seeing the false reading in that tire I had just put in a different blue tooth adapter, the plug in kind. It was cheap and only lasted a few weeks. Went of few days without one(cars not daily driver) bought a new Bluetooth and over the next few days the left rear started to fix it self. First I noticed it say 47psi which I had not seen anything beside 50psi before. It slowly started getting closer the the actual read each time I drove it. After 4 or 5 times go out in it with the new Bluetooth it now reads the correct PSI. Kinda weird not sure if it’s related but the only thing I changed was the Bluetooth plug in adapter and now it works.
Old Jun 17, 2018 | 12:24 PM
saplumr's Avatar
saplumr
If your relearn process works until you get to the troubled tpm it needs to be replaced and while it may be a little more expensive to get a factory tpm you’re better off instead of taking a chance on getting one cheaper on the web that won’t match.
Old Jun 18, 2018 | 06:10 AM
Dano523's Avatar
Dano523
Here is where it nice to have something like the Cub 101, since you can do a quick scan of just the TPMS in question, and see what is actual sending out as pressure once triggered.
Hence if you get 50lbs back on the TPMS itself, have only 32lbs of air in the tire, then you know the problem is the TPMS itself. To take it one step farther, with it reading 50lbs, bank that someone use tire slim in the tire for a flat, the slim dried in the TPMS tire passage, and what killed the TPMS sensor.
If you get a reading back of only 32lbs on the scan tool from the TPMS sensor when the tool triggers the TPMS, then you know that the sensor if fine, and it's a problem between the sensor and the RCDLR instead. On something like this, short battery disconnect to reset the RCDLR in the first place, put the car into TPMS relearn mode, and relearn the TPMS sensors to the car to see if that solves the problem.
If you still have problems, then start checking add on devices that are creating enough RF noise, that is drowning out the TPMS single from reaching the RCDLR correctly isntead.
Old Jun 18, 2018 | 02:25 PM
Killermullet
That Cub tool would be great to have but it looks like anything like that is $150+ now. My DIC reads nothing on 3 of the wheels and XX on one wheel. I talked to the previous owner and he said he never replaced the TPMS sensors so they probably are dead. I'll probably order new sensors as even if that isn't the whole problem, they are 10+ years old. We'll see if that fixes it or if there's more to the issue. Thanks for the responses
Old Jun 22, 2018 | 12:48 PM
Red86Cfour's Avatar
Red86Cfour
I got a cub 101 a few years ago when tire rack was blowing them out for something like 25 bucks.
The sensors are rebuildable if you know how to remove epoxy and have soldering skills/capability. I rebuild mine and have one or two spares sitting on the shelf so that when I change tires (usually only front or rear pair at a time) I can swap out the sensor if its dead.
To 2008 TPMS problems, help please
