Mild or Aggressive cam???
Old Jun 23, 2018 | 06:57 PM
blwnvette's Avatar
blwnvette
Originally Posted by Turbo6TA
And, good choice selecting a cam with 115 LSA ! (in fact boosted engines like yours do better with a higher LSA)
Go much lower than 115, and idle quality also suffers.
BTW ... The OEM LS3 cam has an LSA of 117 degrees and it is [not] advanced ... In fact, it has an ICL of 120 degrees (which gives it 3 degrees retarded)
Yea I have the LS2 eventually I'll get a converter but for the time being with the VRSC-1 I don't think I'll need a converter. It'll be nice to have. I'm going to get valvesprings pushrods oil pump etc as well when I get the cam also I'll do a trunion upgrade
Old Jun 23, 2018 | 09:38 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
That aftermarket cam more than likely has a smaller base circle than your OEM cam ... If so, that will require slightly longer pushrods in order to get the same lifter pre-load as you had with the stock cam.
Check this out ...
Old Jun 24, 2018 | 03:26 PM
sstonebreaker's Avatar
sstonebreaker
Originally Posted by farmington
who called anybody stupid or a liar but you ?????
Yeah, you did.
Old Jun 24, 2018 | 04:29 PM
junk c5's Avatar
junk c5
I could say without a doubt, my cars drivability is near factory with a PTC 4500 rpm stalled converter. Like previously noted, you push the throttle down a tad more and requires a couple hundred more RPM to get the car moving. Well worth it and hardly noticeable. My car would snap your neck if I wacked it from a roll .
Old Jun 24, 2018 | 05:06 PM
hydrasport's Avatar
hydrasport
Will the VRSC-1 cam use stock length push rods or will you to measure and order those after the cam is installed?
Sorry I missed the post answering the question about push rod length.
Do you plan the heads to change the springs?
Old Jun 24, 2018 | 08:50 PM
blwnvette's Avatar
blwnvette
Initially I thought I was able to keep stock pushrod length at 7.400 now I'm not so sure I'll have to speak with VR and see what they say I need I have stock heads no work done to them I was going to get valve springs and pushrods when I get the cam along with an oil pump.
Old Jun 25, 2018 | 01:57 PM
Daniel@Vengeance's Avatar
0Daniel@Vengeance
Former Vendor
Yes, the base circle on our camshafts keeps the ability to use a stock length pushrod with OEM lifters and unmilled heads. That being said, we always highly recommend a dual valve spring kit and hardened aftermarket pushrod with any of our camshafts.
To the OP, feel free to call or e-mail me at any time if I can answer any parts related questions for you on our camshafts/camshaft kits.
- David @ Vengeance
Old Jun 26, 2018 | 12:10 PM
blwnvette's Avatar
blwnvette
Thanks david I'll be giving you a call shortly to order a cam kit from you guys.
Old Jun 29, 2018 | 08:29 AM
blwnvette's Avatar
blwnvette
So I talked to the guys at Vengeance Racing last night to order up a cam. It's a good thing I didn't buy the vrsc1 or 2 being it's for ls3 engines and I'm a ls2. I ended up going with a FTI converter with a VRX4 228/230 .588/.592 112 +4 I'm upgrading my valvetrain as well. This can should wake up my car. I suggest Vengeance Racing to anyone in need of a cam or for whatever you are looking to upgrading on your vette next. Ron and David are great people very helpful and explain everything to you and will answer your questions. Amazing customer service and advice. I'm excited and cant wait for my cam/converter. Thanks again Ron/David @ VR! I'll be calling you soon for a transmission, and good luck in the 1/2mile racing this weekend!
Old Jun 29, 2018 | 09:07 AM
farmington's Avatar
farmington
They still have their sale going?
Old Jun 29, 2018 | 01:06 PM
blwnvette's Avatar
blwnvette
@Farmington yes their sale is still going. I read your post with your custom cam and getting the wrong one. Call ron or david at Vengeance Racing they will take care of you and make sure you get the right cam. They will answer all your questions, great people I would suggest getting a cam from them.
Old Jun 30, 2018 | 10:03 AM
old motorhead's Avatar
old motorhead
That's a blower cam?
Old Jul 5, 2018 | 12:25 AM
  #33
KW Baraka's Avatar
KW Baraka
Originally Posted by old motorhead
…..That's a blower cam?
About +5* of overlap. it can be used with a blower, but I wouldn't call it one.....
KW
