Overheating with a/c on
Old Jun 26, 2018 | 12:05 AM
Jonpfeifer52@gmail.c's Avatar
1st Gear
Default Overheating with a/c on
2003 Z06 overheats when a/c turned on. Have had this problem since new but lived in Alaska . Now live in AZ and it matters now. Any solutions? Pro charger turbo installed a few years ago as well
Old Jun 26, 2018 | 07:43 AM
Patriot Six's Avatar
Patriot Six
You're not getting enough airflow over the radiator at low speeds. Prospeed dual fans with shortened Dewitt's radiator fixed that problem on my supercharged C6Z.
Old Jun 26, 2018 | 09:17 AM
HOXXOH's Avatar
HOXXOH
Welcome to the forum. You're in the C6 section right now, so a mod may switch you to C5 at any time. In the meantime, you probably need to clean junk from the fins on the radiator and condenser from the backside with a water wand. For local info try https://www.arizonacorvetteenthusiasts.net/
I'm your distant cousin, tom pfeifer, here in AZ.
Old Jun 26, 2018 | 09:31 AM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
And to think ... I always thought your last name was 'Hoxxoh' ... As in Mr. Hoxxoh
To Overheating with a/c on
