C6 Base Model Diff
Old Dec 14, 2018 | 05:55 PM
Murray688's Avatar
Murray688
5th Gear
Default C6 Base Model Diff
I just picked up 2006 base model to make track car! I'm doing 15in rear conversion so curious bout power to stock axles! I am going to change gear didn't know if be better to change with Z06 diff and axles or just change gear! I have a 2013 ZR1 makes over 700 never had axel problem with this power and my GS made 608 and never problem! Thx for any insight!
Old Dec 14, 2018 | 06:34 PM
Moved to C6 Tech.
Old Dec 14, 2018 | 07:57 PM
Mike's LS3's Avatar
Mike's LS3
The biggest contribution to a failed C6 differential is wheel hop. As far as oem strength: 2005 < 2006+ < Z06 < ZR1. The two weak areas in a base C6 2006+ differential are the stub axles and pre load springs that are thin and weak. Upgrading the stub axles to a Z06 and installing HD pre load springs address two of the weaker links of the base differential. If applicable, I would get a Z06 differential and axles. Of course, there are further upgrades and its always best to discuss with the professional, i.e. RPM transmissions in Indiana.
Old Dec 14, 2018 | 10:35 PM
Murray688's Avatar
Murray688
5th Gear
Thx for the info! I know gearing different wasn't sure if z06 had more spoline axles! I know my Zr1 has different cooler than Z06 and read Zo6 diff and axles bolt right up! You know th8s to be true! THX
Old Dec 16, 2018 | 02:52 PM
Mike's LS3's Avatar
Mike's LS3
All manual C6 corvettes came with 3.42 gears in the differential. The transmission gears were different, Base, Z51/GS, Z06 and ZR1 all had different transmission gear ratios. Yes, spline count varied on the different model corvette differentials, higher the better.
Old Dec 16, 2018 | 03:02 PM
Murray688's Avatar
Murray688
5th Gear
Thx for the input! Figuring out if I should just change gear or just swap it with Zo6 diff and axles a guy has for $1500!
Old Dec 22, 2018 | 08:46 PM
lowcell's Avatar
lowcell
will the zo6 diff bolt up to an auto trans ?
Old Dec 24, 2018 | 05:25 AM
Tuna Goat's Avatar
Tuna Goat
A Zo6 diff bolted right up to my A6 trans... It drove fine around town but would not shift at all in high rpms without a tune(not even the paddles)
To C6 Base Model Diff
