Diagnose Car shut down
Old Jan 30, 2019 | 01:43 AM
Odo's Avatar
Odo
Yes I understand that, but it also tends to show itself in almost any situation where there is faulty wiring or a faulty module interacting with the ECM, was there anything in this situation that lead to pointing towards it specifically ECM or is that just the best first step approach in your opinion.
Old Jan 30, 2019 | 03:04 PM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default The P0601 code....
The P0601 code.... I sell LOTS of ecms where they get that code and the car shuts down.
BTW.....
[QUOTEalmost any situation where there is faulty wiring or a faulty module interacting with the ECM][/QUOTE] or where the battery is dead, bad alternator, juspstarting,
crossed wires, or ANY other electrical mayhem usually contributes to the ECM failing.... Even if it was actually "good" the moment before the electrical problem.
So,...... REPLACING your baby's BRAIN might be heart failure for many of you... and the DIAGNOSTICS leading up to it are UNCERTAIN and time consuming.....
SO,..... I do my best to make it VERY EASY and INEXPENSIVE to test the car with a REPLACEMENT ECM to take all of the "Heart Failure" out of having to worry
about your baby's dead brain.
In the past, sourcing a replacement ECM meant distress and expense....especially at the dealer or a shop that's not familiar with these things.... For ME, it's pretty quick
and relatively painless to get you into a new ECM... Even if yours was tuned or modified.....or locked....
I GOT YA COVERED!
Chuck CoW
Old Jan 30, 2019 | 07:51 PM
Odo's Avatar
Odo
So it's a good first step.
GOT IT.
Old Feb 5, 2019 | 06:31 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Thank you all for the assistance.
It appears the ECM was getting worse by the day. Suddenly my doors would not open and the radio would power up and dash when attempting to open the door. I had to press the unlock button to get in. The next day the FOB would not open doors at all.
Thank you Chuck
One test drive done and no symptoms of shut down happening.
Old Feb 5, 2019 | 10:28 PM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
Default Told ya! I GOT YA COVERED!
Thank you Chuck
One test drive done and no symptoms of shut down happening. Now to chase down the hot burning smell. Time to inspect brake pads.
Told ya! I GOT YA COVERED! No wasted diag.... no messing around guessing.....
I'm glad it worked out for you!!
Thanks for your business!
Chuck CoW
