12.15@117 on GY runflats with stock GS and 11.70@119 with drag radials only
Received 2,054 Likes
Got invited out to the local V-club track rental and the weather as well prep were better than last weekends opening TNT. DA started out negative and then ended up right around 0 by the time I swapped on the Hoosier drag radials. Started them at 20psi and then went to 16 as the track started to go away, clutch was finicky trying to find the fine line between overpowering the tires and dead hooking causing the pedal to stick though made 4 passes within .04 of each other and 3 within .1 mph (119.6) the slower one with the fastest 60' I clipped the limiter on 1-2 and cost me the 11.6x
is the sticky for the 1/4 time still being updated? If so, you have the fastest showroom stock GS.
https://fastestlaps.com/models/chevr...grand-sport-c6
Just realized I ran faster than any manual C7 with just drag radials ever has...
