Rear View Mirror
The other issue, the loose mirror on the mount, is common. Here are several threads to look at, and I suggest you look at all of them, so you understand what is wrong so you can decide if you want to tackle it yourself. Good luck.
Basic DIY with pics:
https://www.corvetteforum.com/how-to...-mirror-368175
Post 4 a little more explanation and pic:
https://www.corvetteforum.com/forums...post1582804148
Post 1 describing the use of 5/64" drill bits (cut down) for a more permanent fix using the better metal:
https://www.corvetteforum.com/forums...or-repair.html
Post 9 from 2014 (latest I've seen) describing a new GM part number for the 3 pins:
https://www.corvetteforum.com/forums...post1586592829
Took it apart, straightened the pins the best I could, but no joy. The mirror is still loose so I ordered the kit from my local Chevy dealer, should be here by Friday.
I had no idea this was an on-going issue.
Thanks again.
