Bird noise
Old May 6, 2019 | 07:44 AM
shnids's Avatar
shnids
Default Bird noise
I have a 2006 that’s has a chirping noise coming from the front of the engine with little throttle applied. Could that be the harmonic balance.
Old May 6, 2019 | 12:53 PM
jonjoy's Avatar
jonjoy
most likely you could try some belt dressing, A power bond SFI unit is a very good replacement and not too expensive.
Old May 6, 2019 | 07:54 PM
TOM WELCH's Avatar
TOM WELCH
try a new belt, provided yours is old. there are belt measurement tools that can show belt wear to you. I's start there.
Old May 6, 2019 | 09:22 PM
torquetube's Avatar
torquetube
It could. It could also be something else in the accessory drive, like a bearing. Worst case it's internal to the engine, such as a lifter. There seems to be a lot of that going around at the moment.
Old May 6, 2019 | 10:24 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
Don't guess.....get yourself a mechanics stethoscope ($3.99 at Harbor Freight) or a short length of garden hose & listen around all the rotating components at the front of the engine to identify the source of the noise. Hopefully it's something cheap to fix like like a worn serpentine belt or a bad idler pulley bearing or maybe something more serious like the HB going bad. In any case, you'll know the source & can proceed from there.
Old May 11, 2019 | 05:30 AM
Legal Alien's Avatar
Legal Alien
One of the first things ever to go wrong with my Vette was a chirping type noise. Ended up being the exhaust manifold gaskets had perished would you believe? Sounded just like belt chirp but there you go.
You got aftermarket headers?
Old May 11, 2019 | 08:43 AM
shnids's Avatar
shnids
I am all stock except for Borla exhaust
Old May 11, 2019 | 05:28 PM
TTZ06VETTE's Avatar
TTZ06VETTE
Check the idler tension pulley.
Old May 12, 2019 | 06:42 PM
Trebor's Avatar
Trebor
Is the harmonic balencer wobbling?
Old May 12, 2019 | 07:06 PM
oemtech's Avatar
oemtech
Veteran: National Guard
^^^^^^ what he said.
Old May 12, 2019 | 07:24 PM
saplumr's Avatar
saplumr
Squirt some water on the groove side of the belt to eliminate it or eliminate the sound.
Old May 13, 2019 | 07:44 AM
shnids's Avatar
shnids
It is
Old May 13, 2019 | 11:45 PM
FWYSLEEPER's Avatar
FWYSLEEPER
I to have this noise. Sometimes I hear it sometimes I don't. I'm assuming it's the HB.
To Bird noise
