C6 6 speed automatic
Old May 15, 2019 | 10:44 AM
Den's Vet's Avatar
Den's Vet
Default C6 6 speed automatic
I was wondering what model transmission is used for a 2007 LS2
6 speed automatic with paddle shift.
Would that be a 6L80E ?
Thank You
Old May 15, 2019 | 12:38 PM
2006ls2's Avatar
2006ls2
Yep
Old May 15, 2019 | 03:51 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
06-13, not sure on 14?
were there any changes to A6 in 06-13?
Old May 15, 2019 | 03:59 PM
Den's Vet's Avatar
Den's Vet
There was a upgrade on 2012's
Old May 15, 2019 | 04:26 PM
farmington's Avatar
farmington
2012 and 2013 shift much firmer at full throttle and I believe shift at a slightly higher rpm.
Old May 15, 2019 | 09:13 PM
RicK T's Avatar
RicK T
'08 received improved software / tuning which was actually a GM backward compatible upgrade for '06 and '07. GM and tuners would load the '08 software into '06 and '07 cars, tuners would then start their improved tuning with the '08 calibrations.
'10 got a different TCM, '12 received improved software / tuning. '12-'13 are considered the best of the C6 version of the A6. The 2014 C7 version was greatly improved and is considered the best version of the A6.
In short: 06-09 controllers are interchangeable; 2010, 2011, and 2012 are each different and while there might be some similarities it is safest to treat them independently. YMMV on that part.
To C6 6 speed automatic
