Creaking Rear Brake Caliper?
Old May 17, 2019 | 05:25 PM
Anger336's Avatar
Anger336
Default Creaking Rear Brake Caliper?
I’ve been dealing with one of my calipers creaking when pressing in and releasing for a few months now. I had my brakes powder-coated red a little over a year now and they replaced all the seals with new ones of course. Long story short, the one caliper started creaking at one point and they re-lubed the piston/seal area and ground the rust off the slide pins. That fixed the creaking for about a month and it’s been back ever since. Very annoying to deal with lol can anyone help me here? Thanks in advance!
Old May 17, 2019 | 06:46 PM
Kenny94945's Avatar
Kenny94945
Creaking...ummm
Creak went away after rust remove from pad pins and lubing the pins plus lubing the caliper pistons.
I don't think the powder coating process did anything to create a creak.
That leaves:
All mounting bolts.
Caliper piston surface where it meets the pads.
The pads.
The side pins.
What I would do low cost - Remove the caliper, level sand the caliper piston seating surface, replace the pins with new ones, re-lube per the service manual, re-torque all the mounting bolts properly, noting the single use bolts notes (which many disregard and use blue Loctite instead.), re-bleed the system.
Hi Cost - replace the caliper pistons, again new seals, complete clean the caliper, new pins, new pads, new bolts. In other words a complete redo with new parts.
Not an exact answer, as I think one justs needs to "get in there" and look around.
Good luck, let us know if you find the cause.
Old May 18, 2019 | 06:49 PM
NORTY's Avatar
NORTY
Does the brake operate normally?
Is there excessive pedal travel (either service brake or parking brake lever?)
Creaking?
Low speed vs. high speed?
Does it do it when cold and hot?
Old May 18, 2019 | 07:08 PM
Anger336's Avatar
Anger336
Creaking?
Thanks for your reply! No strange pedal feel or service brakes message and it creaks at lower speeds I’d say and at all temps cold or warm. When I’m coming to a stop and releasing the pedal is when I hear it. I guess after the half way point during braking is when it starts.
Old May 24, 2019 | 06:18 PM
Anger336's Avatar
Anger336
Originally Posted by Kenny94945
Creaking...ummm
That leaves:
All mounting bolts.
The pads.
The side pins.
Thanks for your reply! So I took off the caliper few days ago and as I'm taking out the slide pins I notice the top one is rusted and was hard to pull out so I was like aha! I've found my problem! I cleaned the pin as much as I could and regreased the pins and put it all back together. THE CREAK WAS TOTALLY GONE.
Fast forward to today.. I go to O'Reillys and pick up a set of new guide pins that I ordered, head to my garage and take the caliper apart again. I take out the old pins, spray some brake cleaner inside the pin holes and use a screwdriver with a rag wrapped around to get as much of the rust and gunk out from in there as I could. I grease the new pins with Versahem Synthetic Caliper Grease, using a very generous amount making sure there's no friction and assemble it all again. GUESS WHAT.. I start the car and apply the brakes and immediatley the wretched creaking noise is back somehow!?
What is happening here? Am I using the wrong grease or did I not clean the holes enough to get everything out??? It seems like it should've 100% fixed the creaking issue...
THANKS IN ADVANCE FOR YOUR REPLIES!
Old May 24, 2019 | 08:33 PM
Kenny94945's Avatar
Kenny94945
Well, are you using OEM pads?
Are you certain your OReilly pins are the exact same dimensions as OEM.
Well, I guess the cheap fix is to reinstall the pins you just replaced and see if the noise is gone.
I am starting to think this is a pad issue.
Good luck.
Old May 24, 2019 | 08:43 PM
Anger336's Avatar
Anger336
Good luck.
Its pretty strange, the pins are about half an inch shorter actually. But are specific to my car. I’m not sure about the brake pads, I’m not the original owner but it sure seems that they could sure be the culprit! Thanks again for your time!
Old May 26, 2019 | 06:53 PM
Anger336's Avatar
Anger336
So it’s raining today and the creaking is pretty much gone because of the water coming in contact with the caliper I suspect.. any ideas what this could mean?
To Creaking Rear Brake Caliper?
