C6 will not start
Old May 28, 2019 | 02:37 PM
fwlewelling's Avatar
fwlewelling
1st Gear
Default C6 will not start
disconnect the battery & reconnect it starts, what is causing this problem?
Old May 28, 2019 | 03:20 PM
Iceaxe's Avatar
Iceaxe
How old is your battery, that's where I would start looking.
Old May 31, 2019 | 05:58 PM
OregonMike's Avatar
OregonMike
Mine did the same. I still have the 10mm wrench in the console. I swapped out the negative terminal with a wingnut attachment so I didn't have to dick with the wrench because it happened so often.
My column lock kept screwing up as well. I bought the eliminator kit that's been well posted and removed the mechanism inside the column and it hasn't happened since. I'm convinced the steering column lock issue was the whole problem.
There is a fix for the column lock with firmware if you have, or have access to, a tech2 programmer. I do not.
To C6 will not start
