Hi, my tech investigated an engine code.. Says Bank 2, Sensor 1 O2 reads 650. All should be the same reading when key on --engine off. Only this one reads high.
I have a CAM (dont know the specs).. He said might be ECM. He can download the current ECM software , save and upload onto new ECM.
ECM ????...What is the DTC...P0152 ???...When the UPSTREAM O2 sensors are COLD (will read higher with hot O2 sensor) they should read about 450Mv (bias voltage) when you first turn the key on...if you watch that millivoltage it should drop to about 200 Mv or less in 2 minutes...that is how I check O2 heater function with a scan tool...if it reads HIGH have him disconnect the O2 sensor and see if it returns to 450 mv with the scan tool he is using...you might have an O2 sensor or wiring issue...a RICH CONDITION on that bank can even throw that DTC if that is what it is !!
