Secondary Radiator
Old Aug 4, 2019 | 10:58 AM
JasonCzerak's Avatar
JasonCzerak
Default Secondary Radiator
Has anyone mounted a second radiator on a c6? Possibly passenger side using the heater core plumbing and removing the fog light?
The driver side i'd remove that fog light as well and move my oil cooler there.
This is a ECS setup, so i have that big intercooler up front and all the other mods to make that as effective as possible, but i'm still seeing hot temps with light road course work.
Old Aug 4, 2019 | 11:31 AM
jonjoy's Avatar
jonjoy
so you already have a DeWitts or other after market rad?
Old Aug 4, 2019 | 11:43 AM
JasonCzerak
yeah, prospeed fans too. oil cooler is mounted after the radiator but low, that helped a lot with oil temps, but could still be better.
Old Aug 6, 2019 | 04:58 PM
mikeCsix's Avatar
mikeCsix
The fans only help when in traffic on summer days and below 40mph. Putting radiators behind the fog lights won't help much, the fog lights are actually a low pressure area. This subject is covered well in the road racing section.
Old Aug 6, 2019 | 05:12 PM
NYC6's Avatar
NYC6
Road racing is a far cry from a street car, even one pushing a lot more hp then stock. Many of us have additional coolers in the fog light opening( street & some track) and it certainly helps lower temps substantially.
Old Aug 6, 2019 | 05:31 PM
JasonCzerak
I didn't read a couple dozen threads, but the few that I did suggested other wise :/ meh.
Are there any legit options short of going N/A or pulling the intercooler all together and going with a shitload of meth?
Old Aug 6, 2019 | 05:32 PM
JasonCzerak
!!!!!!! YES! Can you please point me to threads on this!
Old Aug 6, 2019 | 05:45 PM
jayyyw's Avatar
jayyyw
I'm going to add a secondary radiator in the rear of the car. I don't run an exhaust so I have all the space where the mufflers used to be.
You can add a small radiator in the bumper/foglight area. It will help but I can't say if it will cure your problems. You will have to make something that can funnel the air into the area.
Old Aug 6, 2019 | 05:59 PM
NYC6's Avatar
NYC6
Check out this section and FI section and do a search on coolers lots will come up. Many say do a very good aftermarket rad like Dewitt’s and add oil coolers in one or both fog lights, or one through the rad and one behind fog. My car is S/C’d and had trouble overheating oil, coolant and transmission. I did the Dewitt’s with EOC and Trans cooler then added a B&M cooler for the trans also and temps are much better even when getting on it hard in 90* temps. Heavy duty track runs in hot weather I can’t speak about.
just read ahead to your later post and you already got a good understanding and have implemented them.
Old Aug 6, 2019 | 06:36 PM
Unreal's Avatar
Unreal
Can goto a smaller intercooler, intercooler behind the fog light, or air to water. Everyone wants these huge intercoolers, but then can't keep the car cool. When I did a custom intercooler I choose one that still gave me tons of cool air flow to the radiator.
Old Aug 6, 2019 | 06:52 PM
JasonCzerak
The ECS one is not huge, keeps IAT's around 145@165mph@90degree temps which is not horrible
Is your IC front mounted?
Old Aug 7, 2019 | 11:41 AM
Unreal's Avatar
Unreal
Yes it is front mounted. I never had issues with the stock ECS one. Worked great. Upgraded to one 250% bigger, and still don't have issues after I added an oil cooler.
A lot of people do stuff like the PC Race one, that completely blocks the radiator.
Old Aug 7, 2019 | 12:10 PM
Sox-Fan's Avatar
Sox-Fan
As an N/A guy I look at that IAT temperature and my eyes kinda bug out a little.
Old Aug 7, 2019 | 12:30 PM
JasonCzerak
My tuner tunes one of the fastest stock LS2 bottom end cars and says IAT's are around 200 and it lives (for now?)
Old Aug 7, 2019 | 12:34 PM
Unreal's Avatar
Unreal
140+ on a blower car isn't bad at all. Compressing the air causes a huge increase in heat. A lot of PD blower stuff see 200-250+ on pulls.
Old Aug 7, 2019 | 12:36 PM
JasonCzerak
I dont' recall what my old novi1500-sl was doing for temps, but I do recall how many times I destroy the bearings. I think keeping this YSI well under-spun, yet making decent power was a wise choice for IAT's and just over all reliability (except for that ******* $50 seal behind the impeller)
Old Aug 7, 2019 | 11:22 PM
C6 4 AL's Avatar
C6 4 AL
Default secondary radiator
I have a Ron Davis radiator, engine oil cooler behind driver side fog light and trans oil cooler behind passenger side fog light. That is what it took to make my C6 auto run at cool enough temps to do track days here in Southern California.
Old Aug 8, 2019 | 12:55 AM
DrackVB's Avatar
DrackVB
Check out Post #151 for this guys Dual Oil cooler setup.
https://www.corvetteforum.com/forums...d-7-7-a-8.html
Gspeed setup
https://www.youtube.com/watch?v=stMR...r2heLW_Bp4DEIA
Old Aug 8, 2019 | 12:56 AM
DrackVB's Avatar
DrackVB
C6_4_AL: What coolers are you running in the fog lights. Trying to decide between a Setrab series 6 34 row unit or an MHX-520 from Improved racing.
To Secondary Radiator
