replace c6 RCDLR PROGRAM?
Old Aug 19, 2019 | 07:27 PM
tonycorvettes's Avatar
tonycorvettes
Default replace c6 RCDLR PROGRAM?
I got it running don't need tech2 WHEN u replace a RCSLR does it have to be programed by a dealer? or can you plug and play ,this is a 2005 ;
Old Aug 19, 2019 | 08:17 PM
SixAddict's Avatar
SixAddict
When I helped a fellow member do this we used my tech2. You should post in your area for that help. The stealership will charge you to death........
Old Aug 24, 2019 | 01:38 PM
tonycorvettes
was it complicated? or piece of cake with a tech 2 ..cause ill buy one ,just don't trust dealers
Old Aug 24, 2019 | 03:05 PM
Dano523's Avatar
Dano523
Which receiver?
The steering column lock module behind the gauge cluster?
Most of the time they are plug and play if you get the right new one for your car year model. On say a used one, may need to be security married to the BCM instead.
As for the Remote control door lock receiver (above the radio in the dash), that one will need to be firmware flashed to marry with the BCM, then you still have to program the fobs and TPS back in next.
As for flashing/programing, anyone with a Tech II and TIS2000 program will have you covered (will need a TPS trigger tool to program then back into the RCDLR).
Old Aug 27, 2019 | 12:31 AM
tonycorvettes
how do I get these?TIS2000 program and a TPS trigger tool
Old Aug 27, 2019 | 03:31 PM
Dano523's Avatar
Dano523
Will need a device for pass through between the car and the laptop. Tech II clone, VX GM Nano, or even Mongoose pro will work.
As for TIS2000, easy to find a cracked version to download for free.
As for setting up TIS2000, since it runs on windows XP, either need to have a machine set up in XP, or a multicore machine that you use to build a VM shell in XP, then load the Cracked TIS2000 on top of that.
As for TPMS trigger tool, they are pretty cheap as well.
https://www.amazon.com/Autokcan-Relearn-EL-50448-Pressure-Monitor/dp/B07QCXFF46/ref=asc_df_B07QCXFF46/?tag=hyprod-20&linkCode=df0&hvadid=343221129804&hvpos=1o1&hvnetw=g&hvrand=13017972605071144594&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9011800&hvtargid=pla-751149581224&psc=1&tag=&ref=&adgrpid=74547732412&hvpone=&hvptwo=&hvadid=343221129804&hvpos=1o1&hvnetw=g&hvrand=13017972605071144594&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9011800&hvtargid=pla-751149581224 https://www.amazon.com/Autokcan-Relearn-EL-50448-Pressure-Monitor/dp/B07QCXFF46/ref=asc_df_B07QCXFF46/?tag=hyprod-20&linkCode=df0&hvadid=343221129804&hvpos=1o1&hvnetw=g&hvrand=13017972605071144594&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9011800&hvtargid=pla-751149581224&psc=1&tag=&ref=&adgrpid=74547732412&hvpone=&hvptwo=&hvadid=343221129804&hvpos=1o1&hvnetw=g&hvrand=13017972605071144594&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9011800&hvtargid=pla-751149581224
Once the RCDLR is flashed, then Fobs programmed into it, you put the car in to TPMS relearn mod with a fob, the use the tool to trigger the tire sensors starting from the driver front tire, then clockwise around the car to trigger each tire sensor one at a time to learn them to the RCDLR.
Old Aug 28, 2019 | 01:35 AM
tonycorvettes
man im sorry I started all this,now im dead in the water,car ran great b4 I messed with it,is there anything I can do to start this thing and just give it to the dealer..this damn lock out password thing
Old Aug 28, 2019 | 03:40 AM
Mikha Motorsports's Avatar
Mikha Motorsports
Let's rewind a little here... Why did the vehicle need an RCDLR? Seems like if it needs an RCDLR to begin with, you already started with serious problems.
Old Aug 28, 2019 | 11:47 AM
tonycorvettes
I was trouble shooting a drivers door wont open ,and did not hear a click when I tried to open drivers door at the rcdlr,i did hear it doing the passenger door,
Old Aug 29, 2019 | 12:30 AM
tonycorvettes
wow I got it running thanks to youtube go here
theres a 4 time try to start procedure it will start and relearn your password from your old rcdlr out of sight,now I can drive it to the dealer and get it fixed right,,,,supream Chevrolet says 2hrs labor and 200.00 for the part
Old Sep 23, 2019 | 09:12 PM
tonycorvettes
turns out rcdlr was good,, found at the door jam the actuator connector wa not making good connection
Old Sep 23, 2019 | 11:29 PM
SixAddict's Avatar
SixAddict
Wow lot of issues for that being the issue. Glad you got it figured out and thanks for posting a conclusion to your issue.
Old Sep 24, 2019 | 08:09 AM
maverickmk's Avatar
maverickmk
Yes, thanks OP. So many threads do not end with the fix and are pretty much useless when people do a search.
Old Sep 24, 2019 | 10:26 AM
Nowanker's Avatar
Nowanker
Pro Mechanic
...Glad you got it figured out and thanks for posting a conclusion to your issue.
Second that!
It helps us all out by posting the solution, instead of just going dark after getting it figured out.
Pay it forward!
Old Sep 24, 2019 | 03:50 PM
wjnjr's Avatar
wjnjr
Glad you found the fix, thanks for sharing
Old May 1, 2023 | 08:01 PM
slowc6er's Avatar
slowc6er
2nd Gear
im having the issue where i cant even open my doors or anything, car wont even power on unless i disconnect the batery for a min and re connect. would this be a rcdlr issue??
Old May 1, 2023 | 11:16 PM
SixAddict's Avatar
SixAddict
How old is the battery?
Have your battery tested. Or better yet replace it, these cars do crazy things when battery starts to go.
I would say this isn’t an rcdlr issue, sounds like a battery issue.
Old May 2, 2023 | 06:39 AM
slowc6er's Avatar
slowc6er
2nd Gear
did that brand new battery, brand new terminals.it acts like it doesnt detect the fob at all any where near the car, even when i put it in the glove box.
Old May 2, 2023 | 01:04 PM
SixAddict's Avatar
SixAddict
I’m not sure what all you got going on then. I’m sure since you replaced the battery you also did the fob batteries. (Also new batteries can be bad out of the box).
Do you hear any clicking going on behind the ac vents at top of console when you put your foot on the brake pedal?
If not then it maybe your rcdlr. I would first check fuses under the hood and at passenger footwell. Check you cable connections at the starter, the grounds going to frame.
https://www.corvetteforum.com/forums...vice-help.html
here is a link to the grounds and other connections to maybe check. Scroll down to get to diagram and thank 4SUMERZ.
To replace c6 RCDLR PROGRAM?
