2005 E40 ECM Pinout
Old Dec 16, 2019 | 09:14 AM
MTBSully's Avatar
MTBSully
Default 2005 E40 ECM Pinout
Anyone have a pinout for the E40 ECM on my 2005 corvette? Specifically the C3 gray plug on the top? I pinned the ECU for flex fuel and want to double check my work as I started the car last night and dash is reading "oil pressure XXX". Want to double check that is is not affected by that connector.
Old Dec 16, 2019 | 10:45 AM
Dutch08's Avatar
Dutch08
Old Dec 16, 2019 | 01:24 PM
4SUMERZ's Avatar
4SUMERZ
I only have the 2006/2007Service manual, and thus I'm not sure if the pinouts are the same. I have attached the 2007 ECM connectors/pinouts. The ECM C2 connectors shows it as GY, so I've attached it. You can have a look to see if it is like yours.
File Type: pdf
Old Dec 16, 2019 | 03:05 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
2006/7 aren't the same ECM.
Old Dec 16, 2019 | 03:07 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
This is from a GTO but should be close if not the same.
Old Dec 17, 2019 | 08:13 AM
MTBSully's Avatar
MTBSully
Hmm, not sure if thats accurate for the vettes. Mine seems to have different pin locations
Old Dec 17, 2019 | 08:25 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Ah, crap. Ok, I'll try to pull it off the GM service software I have, let me see if I can find it there
Old Dec 17, 2019 | 08:35 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Here ya go... this one is straight from GM's service software.
File Type: pdf
Old Dec 17, 2019 | 06:09 PM
MTBSully's Avatar
MTBSully
You da man. That matches up perfectly with the pic I have of the pins in mine. Looks like oil pressure signal isnt on that connector. I wonder if the sensor just went bad.
Thanks!
Old Dec 17, 2019 | 07:37 PM
4SUMERZ's Avatar
4SUMERZ
It's possible that the oil pressure sensor went bad. A thread on here yesterday asking how to get to it to replace.
https://www.corvetteforum.com/forums...re-sender.html
Old Dec 17, 2019 | 09:29 PM
MTBSully's Avatar
MTBSully
Yeah I suppose its possible. Car hasnt been started since October. I verified oil pressure at the turbo oil feed, and the lifters seemed very quiet, so I am sure it has pressure. Just seems strange it would go bad suddenly
Old Dec 18, 2019 | 09:07 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Happens all the time. They’re cheap, I’d just replace it and see what happens. Those things fail pretty often
Old Dec 18, 2019 | 06:05 PM
MTBSully's Avatar
MTBSully
Yeah I'll give it a shot. Always alarming to see no oil pressure on the dash haha
Old Dec 18, 2019 | 11:35 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Ah. Yeah they usually fail at max pressure so hopefully yours is just an odd case.
Old Dec 19, 2019 | 11:12 AM
MTBSully's Avatar
MTBSully
Mine says "oil pressure XXX" which i believe means there is no signal at all from the sensor. Same thing happened when i did my cam swap on my z06 a few years ago and bumped the sensor off re-installing my intake manifold. If there really was no oil pressure Im sure it would read "oil pressure 0psi" and I would have a very loud valvetrain haha
Old Dec 20, 2019 | 10:22 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Ah, yeah that does sound like it's not connected at all then.. still not a bad idea to try a sensor while you're at it but yeah I'm sure you have pressure or you'd know it by now
To 2005 E40 ECM Pinout
