C6 passenger window regulator problems
Old Apr 7, 2020 | 12:00 PM
C6artic's Avatar
C6artic
1st Gear
Default C6 passenger window regulator problems
Hi I have a base 2006 c6 corvette
before this issue the passenger side window worked as it should, the right side door shell was damaged and I replaced just the shell, I removed all parts from my old door and installed it on my new door,
Installed the same window regulator.
when I put everything back the window will go down but will not go back up, I do have a scanner that I can command the window to go back up but that's where is stops.
I've tried window indexing reset
Battery is at 12.5 volts off and about 14 volts when car is running
Any ideas? Thanks
Old Apr 7, 2020 | 05:02 PM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Default Window
Any ideas? Thanks
. With the window down and both doors closed press the window switch down for 5 seconds and then see if the window will come up and hold up switch for 5 seconds. Do this from the drivers door only. Obviously either running or in accessory mode
