Rocker arm help needed
Old Apr 27, 2020 | 02:35 PM
bada's Avatar
bada
Default Rocker arm help needed
Crane no longer make a rocker arm. For a LS7 ZO6 motor. I am making around 650HP. It is a NA motor. Cam has a lift of around 650/650. Looking for recommendations. I have done some searching. Some say stock LS7 rockers are good. Not sure, but I shift at 6800 RPMs. This is in a 32 ford truck, with a turbo 400 tranny.
Any advice on what you guys use.
Thanks Robert
Old Apr 28, 2020 | 09:02 AM
irok's Avatar
irok
The stock rockers will be fine for 6,800 rpm except for the needle bearings in the trunions some times fall into the engine and destroy it.I avoid that issue by replacing the needle bearing trunions with CHE manganese bronze bushings in the trunions.A trunion bushing will carry 300 times the weight of a needle bearing spread across a much larger area.Check them out on line. Cost is about $200.
Old Apr 28, 2020 | 11:39 AM
bada's Avatar
bada
I did a little research. And the CHE kit is what I am going with.
Old Apr 28, 2020 | 12:07 PM
Creatre's Avatar
Creatre
I have the comp cams bsr system if you wanted something a little more expensive. Seems to be working well so far. It's basically the stock rockers on a shaft which should help stability in the higher rpms.
Old Apr 28, 2020 | 01:33 PM
subfloor@centurytrans's Avatar
Supporting Vendor
2024 C6 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
Thanks Robert
Been running stock rocker arms for over a decade now on two different LS7 powered drag cars with an even bigger cam than yours. Never had it on a dyno but based on my ET and MPH I'm probably at around 600rwhp.
I shift between 7200 and 7500 RPM and after thousands of passes I've never had an issue.
To Rocker arm help needed
