Lifter noise
Old Jun 14, 2020 | 10:12 AM
Mikes_mess's Avatar
Mikes_mess
4th Gear
Default Lifter noise
My first Ls7 Iv rebuilt, and love it. the ls7 lifters were in short supply about 4 months ago, so I went with some “Engine Pro” brand from EPW. It’s quiet at idle but around 22-2500 rpm it’s a little noisy. I don’t know if this is a ls7 thing or if I should go up a little on oil thickness. I’m running 5/30 M1 now. When the engine is cold it’s quiet. Thanks for advice!
Old Jun 14, 2020 | 10:52 AM
grpweld's Avatar
grpweld
Are you sure it's not the injectors you are hearing?
Tell us a bit about your rebuild! heads, cam? if so how much pre-load on the lifters?
Old Jun 14, 2020 | 11:05 AM
Mikes_mess's Avatar
Mikes_mess
4th Gear
it’s 100% stock rebuild. I used all GM parts, and had my cylinder head guy put in new GM valve guides. My preload was .060
Old Jun 14, 2020 | 11:25 AM
grpweld's Avatar
grpweld
After market lifters could be different height causing a need for longer or shorter pushrods! Did you check lifter plunger travel?
Old Jun 15, 2020 | 08:23 PM
NY09C6's Avatar
NY09C6
Most LS engines have a noisy rpm range. Mine is most noticeable in the 1800-2200 range. Totally stock car. it does reduce running a heavier oil
Old Jun 15, 2020 | 10:26 PM
Mikes_mess's Avatar
Mikes_mess
4th Gear
I will try it. Not bad just annoying I can’t figure out what it is. Thank you for the reply. Btw, That’s the same range mine is.
To Lifter noise
