Camshaft upgrade
Old Jul 30, 2020 | 11:23 PM
dkoch's Avatar
dkoch
Default Camshaft upgrade
Hi folks.
I have a 2013 Grand Sport. Auto trans.
Does it make sense (like in the old days with performance upgrades) to step up to a hotter cam? Nothing crazy where lots of other parts need to be changed out. But simply a bump up from the stock cam.
Thanks. You guys are always so smart and helpful!
Derrick
Old Jul 30, 2020 | 11:42 PM
Omega Doom's Avatar
Omega Doom
of course there are plenty of great mild cams i would suggest looking into a Cam Motions mild stage 3 cam which you can use without a stall converter upgrade
Old Jul 30, 2020 | 11:47 PM
dkoch's Avatar
dkoch
Ok great. And would there need to be some reprogramming done to the fuel and timing systems with a mild cam?
Old Jul 31, 2020 | 09:23 AM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Changing the camshaft really does require some re-tuning (calibration).
Unfortunately, having the car dyno tuned will more than likely cost you more money than what you paid for the camshaft alone.
Old Jul 31, 2020 | 09:38 AM
old motorhead's Avatar
old motorhead
If you change the cam, you need to change the valve springs too. Also, I wouldn't do a camshaft upgrade without adding long tube headers. If you want to leave the stock exhaust system, alone and not do springs, just adding a centrifugal blower might be a better route. You can have a very nice power bump while keeping stock like manners with the blower. As mentioned above, you'll need a tune no matter which way you go. Your fuel pump is fine unless you go much over 550 rwhp.
Old Jul 31, 2020 | 12:03 PM
dkoch's Avatar
dkoch
Ok. Now adding a blower of course is great. But there we are talking a big jump in total costs over just a cam & tuning upgrade?
Old Jul 31, 2020 | 12:42 PM
Withnasty's Avatar
Withnasty
outright cost, big jump yes. dollar per horsepower its cheaper, plus it doesn't impact driveability. just depends what trade offs you're willing to accept.
Old Jul 31, 2020 | 12:46 PM
dkoch's Avatar
dkoch
Excellent information here.
Now I guess I should talk to a good shop to do the work.
I can have it done in -
Las Vegas
Southern California
Phoenix AZ
Any recommendations for a pro shop?
Old Jul 31, 2020 | 01:08 PM
Turbo6TA's Avatar
Turbo6TA
You are going to find that the labor cost is going to be higher than a cam change in many other cars ... Because the power steering rack sits right in front of the harmonic balancer on the C6. And because pulling the steering rack in order to remove the harmonic balancer is very time consuming, the labor cost is high.
As far as parts, you will need:
1. Camshaft
2. 1 Bolt to 3 Bolt Cam Conversion Kit (Most aftermarket cams are a 3-bolt design)
3. Valve Guide Seals
4. Front Cover, Valve Cover and Water Pump Gaskets
5. Front Crankshaft Seal
6. Upgraded Valve Springs
7. Hardened Pushrods
And a word of advice .... Since the harmonic balancer needs to be removed in order to access to camshaft, I would replace your OEM balancer with a good aftermarket balancer when changing the cam ... Why? ... Because the OEM balancer is prone to failure. You may have already heard about the 'woobling' problem with the stock balancer before. Change it out when changing the cam ... If you don't do it then, and have a failure later on, it's going to cost you a bunch of $$$ to replace it then.
Old Jul 31, 2020 | 02:41 PM
dkoch's Avatar
dkoch
Great tip on the harmonic balancer.
You would think by now they would have used a better quality unit from the factory.
Old Jul 31, 2020 | 04:31 PM
Chiselchst's Avatar
Chiselchst
Before you start, I'd suggest your determine exactly what your goals are? Project creep is common, and it's always better to do everything at once to save $$$...once you've established what your goals are. Higher power = stickier tires, etc. You get the idea.
PS As far as bang for the buck, a supercharger is the most efficient way to boost power for the $$$, IMHO
Old Jul 31, 2020 | 04:36 PM
Chiselchst's Avatar
Chiselchst
I highly recommend Cordes Performance Racing, in Tempe, AZ
https://cordesperformanceracing.com/
Las Vegas
Southern California
Phoenix AZ
Old Jul 31, 2020 | 07:53 PM
BluegrassMotorsport's Avatar
BluegrassMotorsport
My car is down for a camshaft upgrade currently and I also decided to do some preventative maintenance while they're in there. I'm replacing the harmonic balancer, timing chain, and spark plugs & wires. I'm also having him change and flush the clutch fluid too. Might as well do as much as you can since so much of these cars have to come apart for the camshaft.
Old Jul 31, 2020 | 08:49 PM
saplumr's Avatar
saplumr
I see you’re in Kentucky so is bluecat doing it or someone else?
Old Jul 31, 2020 | 09:05 PM
BluegrassMotorsport
Bluecat is supposed to be doing the tuning, yes. But he's slammed getting ready for LS Fest and I don't want my car sitting for weeks. So we'll see. He's one of the best in the business so I hope it doesn't take long because I'd like him to do it.
Old Jul 31, 2020 | 09:24 PM
saplumr's Avatar
saplumr
Once upon a time he was set to do some work for me but he stopped communicating with me and would answer calls. Don’t know if he underbid the job or what but I don’t want to chase someone to do my work.
Old Jul 31, 2020 | 09:52 PM
BluegrassMotorsport
That's basically been my story from the get-go on this whole project. Everyone "wants" to do the work but no one can give you an estimate on anything (labor, time, tune, etc). I finally found a good mechanic who won't take a month to do a cam swap. Next trick will be getting it tuned. If Bluecat don't come through then I'm going the PCM mail-in route because I can have one back to me in a few days. It's risky but the reflash is only $50 if I want to update something. This whole process has been nuts from the start. I'll be happy when it's over haha.
To Camshaft upgrade
Old Jul 31, 2020 | 10:02 PM
saplumr's Avatar
saplumr
RPM Transmissions hooked me up with Mayhem Motorsports in Raleigh and they did a tremendous job on my last round of mods.
Old Jul 31, 2020 | 10:11 PM
BluegrassMotorsport
Thanks! I called PCM of NC this week and they were so nice and helpful. I'll check Mayhem out too.
Old Aug 1, 2020 | 01:22 PM
Chiselchst's Avatar
Chiselchst
That's why I went with Joe, at CPR. Estimate up front and no surprises. Plus they do a lot of these and their experience is priceless, IMO...
