Header question
Old Nov 6, 2020 | 10:20 AM
Z97's Avatar
Z97
Cruising
Default Header question
Hey what's going on. New to the LS life so don't flame me too bad lol. Been looking at long tubes along with X-pipe. Pretty sure I've decided mostly on a set but I want to hear some insights before I really buy.
I've tried to google the answer more or less and my conclusion is not a huge difference in power for NA power.
Header collector spike vs no spike. I know I'll lose some scavenging but I wonder if it's really a big draw back.
Car for reference is a LS3 that will just be bolt ons until I decide to do a heads/cam setup in the future.
Thanks!
Old Nov 6, 2020 | 01:37 PM
farmington's Avatar
farmington
ANY set of headers will be ok. You will need a tune.
Old Nov 6, 2020 | 01:56 PM
JUICED1's Avatar
0JUICED1
Former Vendor
95% of all headers out there for the C6 will be the same. All power output is similar, we usually see 35-40rwhp with a tune. The biggest difference is quality and fitment. You get what you pay for. If you need any help selecting yours pm us or give us a call. Always glad to help out.
You don't need a tune but it's highly recommended. You will get a check engine light with headers, if not right away it will eventually pop up. We have been offering a free tune if you order HP tuners from us.
Old Nov 6, 2020 | 02:20 PM
Sayfoo's Avatar
Sayfoo
"95% of all headers out there for the C6 will be the same. All power output is similar, we usually see 35-40rwhp with a tune"
I find this very interesting.
I wonder what the increase would be with just a tune?
I'm tending to think that the tune accounts for most of the gain.
Obviously, headers should be a plus. Definitely with old school exhaust manifolds. But with the c6/ls3 exhaust system, I wonder.
An example of gains with a better system would be the factory npp system. A straight through muffler pipe vs a 180+ deg turn in the mufflers, only equals 6hp.
So with a stock engine with just bolt on's, other than the coolness factor, are headers really worth the price and potential problems?
Old Nov 6, 2020 | 02:33 PM
Z97's Avatar
Z97
Cruising
That's a very solid deal. I bought the car second hand and the previous owner has been shady to say the least. Supposedly it's "Catless" currently so I'm very used to the cat efficiency codes lol.
What all is needed besides the credit for HP tuners?
Old Nov 6, 2020 | 03:06 PM
Z97's Avatar
Z97
Cruising
From what I've seen, headers are always solid gains after a tune. It'll pick up some without a tune but its gonna be running rich to compensate for the better air flow.
I'm more or less interested in the spike in the collector vs not and if it's really that big of a deal.
Old Nov 6, 2020 | 07:36 PM
Sayfoo's Avatar
Sayfoo
That's true, but how much would you gain with just a tune?
What do headers cost, installed?
https://www.corvetteforum.com/forums...dyno-tune.html
You can get a nitrous system for less than $1k, plus installation (most home mechanics could install these themselves).
Cost vs value/hp does matter.
Old Nov 6, 2020 | 08:23 PM
Z97's Avatar
Z97
Cruising
Nitrous gets expensive in the long run and deleting cats would be a massive suggestion lol. I'm going to be doing the header install so labor isn't a worry. I'm sure someone would charge like 300-500 to install them realistically. Just need to wrap all the lines that are close to the headers to ensure nothing melts and general maintenance items such as plugs & wires.
Dyno tuning may yield 15-25 whp maybe more. We'll see when that road comes about lol
Old Nov 11, 2020 | 07:09 AM
Hawkdriver's Avatar
Hawkdriver
I’m currently installing Speed Engineering with TSP X-pipe. So far the easiest install I’ve done. Doing it on jack stands up about 20 inches. Headers when right in
Old Nov 11, 2020 | 07:11 AM
3X2's Avatar
3X2
My preference is ARH. These seem to make the most power on the dyno. Whatever brand you choose, here a few things I do when installing headers. Some may not be needed.
1- wrap the starter housing and solenoid.
2- use metallic heat shield (i.e. DEI) on the primary tubes closest to the starter and oil cooler pipes, secure with metal self locking band straps. It comes in sheets, cut as needed with tin snips.
3- I cut the tunnel plate into 2 pieces right where there is a notch in the tunnel, between the 4th and 5th bolt, and notch one side of the plate then run the O2 wires up in between the tunnel plate and torque tube.
4- fire sleeve the O2 connectors and secure as far away from the headers as possible with wire ties.
5- fire sleeve the 2 trans cooler pipes where they go over the right side header collector.
6- wrap the right side header collector at the trans cooler pipe area, see #2.
7- fire sleeve the 2 heater hoses.
8- add additional fire sleeve to the wire harness behind #8 primary tube.
9- add a small piece of fire sleeve over the purple wire and connector on the starter solenoid.
10- rotate the knock sensors as needed for additional clearance and secure wiring with wire ties.
11- fire sleeve the clutch slave cylinder line.
12- depending on header brand, heat shield #7 primary tube if close to slave cylinder line.
13- add heat boots to the plug wires and secure the coil end with wire ties.
14- if not already there, fire sleeve the engine mounts.
15- use high temp antisieze on all the bolts and the oxygen sensors.
16- no header wrap. I also have had high temp coatings peel off. may work ok for a street car.
17- check for clearance between the chassis flange and where the 4 tubes join the collectors on both sides. Depending on header brand, I have had to bend the chassis flanges with a hammer. Not required on aluminum frame cars.
Old Nov 11, 2020 | 08:18 AM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
My bone stock 2011 GS / LS3 with automatic trans: 371 RWHP on the Dynojet
Added 1 3/4" headers with cats and a dyno tune: 405 RWHP on the same Dynojet
Gain of 34 RWHP
Old Nov 11, 2020 | 08:30 AM
Dano523's Avatar
Dano523
Old Nov 13, 2020 | 06:57 AM
jonjoy's Avatar
jonjoy
Should have put 1 7/8 on an LS3, and I hate too say it because the forum engineers are going to flame me but. You would have got that bump from the tune alone, my LS2 347.4 after just a tune 379.9
Old Nov 13, 2020 | 12:07 PM
Z97's Avatar
Z97
Cruising
They look visually easy to do from top side of the car. You dry sump or not?
Old Nov 13, 2020 | 01:59 PM
Sayfoo's Avatar
Sayfoo
Great, this is what I'm trying to learn.
99% of what I read is that with headers and a tune, I'd get xx% increase.
Since the ls3 manifolds are pretty good, I wondered where the major increase would be.
As I posted before, the npp option is only good for 6hp, and it deletes a major obstruction in the mufflers/exhaust system.
Old Nov 14, 2020 | 12:51 AM
HOXXOH's Avatar
HOXXOH
Don't get concerned with things like spike vs no spike, until you've extracted most of the fruit at the top of the tree. Once you understand the flow as related to heat, volume, velocity, and that can physically work within the confines and limitations of your car, you'll see that spikes are an expensive waste of resources for a street driven car. Also be aware that wrapping exhaust parts to protect other heat sensitive parts will change the dynamics of exhaust flow. We don't have the technology to extract the maximum power through optimization of the exhaust system, so we are left with compromises of what is currently available.
Old Nov 14, 2020 | 01:39 PM
jonjoy's Avatar
jonjoy
If you remove one of your exhaust manifolds and look at it from behind u you ou will see what is basically a cast iron shorty header is it as good as a long tube header NO, but GM did not get to 435 on accident they Know what their doing. The days of "uncorking" a 350 with an intake and carb and headers and getting a hundred horse are over. LT headers are probably more helpful for keeping the Torque numbers close to the HP. As you mod cam, intake,tune, the numbers will get further apart with a stock exhaust. Keep this in mind a base vette has 5 inch exhaust 2 1/2+2 1/2 =5. A 6cyl 650 HP Diesel engine in a class 8 truck 20? Liters? Uses a single 5-6 exhaust pipe. Best advice Read read and read some more and save yourself a lot of money by learning from somebody's else mistakes
To Header question
Old Nov 14, 2020 | 02:12 PM
farmington's Avatar
farmington
If you do the math, 2 2.5” pipes have half the area of a single 5” pipe.
Old Nov 15, 2020 | 08:59 AM
jonjoy's Avatar
jonjoy
My point is still made, love the forum engineers, went from stock LS2 intake manifold to radically ported LS2 I lost HP, HOW? Lost velocity, went from that too a FAST gained that back plus ten, HOW Velocity, put long tubes on your car, put the wrong size on you can lose HP, My point is about the stock system or after market that there is more the enuff pipe for flow and muffler for VOLUME in the system, yes volume GM accounts for how much storage space for exhaust gases on the way out,
Old Nov 15, 2020 | 09:18 AM
farmington's Avatar
farmington
The ls2 intake has been known as junk from day 1. Porting one is like putting perfume on a pig, it smells nicer but it’s still a pig. There are very few engine mods that will give you positive results in 100% of the curve. You need to decide where you want improvement and focus on what you need to get you there.
