6L80E Hard Down auto Shift
Old Nov 26, 2020 | 11:42 AM
Charliemopic's Avatar
Charliemopic
Default 6L80E Hard Down auto Shift
2007 Corvette with a stock 6L80E.
Mods are an EForce making 7psi and headers. It has been dyno tuned.
It makes 430wtq at 3000rpm and
450 wtq at 3200rpm.
Since being tuned,
when Im cruising along around 35 to 45 mph in Drive and floor it it downshifts into passing gear as it should but it hits the lower gear/passing gear so hard it feels like something is gonna break.
This is with run flat tires so its not power going to the ground its the trans hitting hard, too GD hard.
A friend has the same car with same mods except his down shift does not hammer into passing gear. His down shifts smoothly.
My car up shifts on its own (not using paddles)in D and S fine.
Using paddles to down shift like for a roll race works fine.
Its just the automatic downshift, when in D under hard accel that hits too hard.
Any ideas on what this is?
This winter its going back to same shop for a fuel sys, flex fuel conv. and tune.
Thanks guys
Old Nov 30, 2020 | 05:54 PM
da6speed's Avatar
da6speed
I wouldn't floor it and go WOT from a cruising speed or high gear as from what I've been told that is a good way to tear something up.
Either ease accelerator down gradually to get it to downshift a gear at a time or pull shifter in S and bump down with paddles and then floor it.
Old Nov 30, 2020 | 09:13 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Downshifts can be adjusted in the tune.
Old Dec 1, 2020 | 09:12 AM
Garymorris's Avatar
Garymorris
Those multiple gear downshifts is what destroys 6l80/90's. Use the paddles to downshift first.
Old Dec 1, 2020 | 11:43 AM
subfloor@centurytrans's Avatar
Supporting Vendor
2024 C6 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
It's not that multi gear downshifts are necessarily harmful, just the 4 gear ones which is likely what happened to the OP.
There is a LOT of torque management built into the tune whenever you try downshifting from 6-2 or even 5-1. That's why the car will actually feel quicker if you only lay into the throttle slightly instead of flooring it.
Although it can be tuned out I wouldn't recommend it.
To 6L80E Hard Down auto Shift
