09 A6 Shifter won’t shift
This is the grommet I put on the front. It is the wrong one? Or is it supposed to be the clear one
Also, when you do go to put the cable back in with the new end grommets on the trans last, unlock the end of cable length piece, put the trans into neutral, shifter into neutral, then get the cable to correct length installed (to account for cable stretch), lock the adjuster, pop the grommet back out to reinstall the red hood, and then reinstall the cable on the trans shifter linkage.
https://www.corvetteforum.com/forums...djustment.html
