Brake job
Old Jan 3, 2021 | 01:46 PM
okgo's Avatar
okgo
Default Brake job
I have a 2012 grand sport convertible want to change the brakes
I do not track the car what are the best pads and do I have to resurface the rotors I almost forgot it has 27,000 miles
Old Jan 3, 2021 | 07:21 PM
Chatman's Avatar
Chatman
I replaced pads last week for an upcoming track day. If your caliper bolts are like those on my 11 GS then they were hard to remove because of some original factory locktite on the bolts. I needed a pipe extension for more leverage. Just want to give a warning.
Lots of opinion here about pads. Your rotors are most likely fine if you currently stop without vibration. You should probably replace brake fluid if you haven’t done so.
Old Jan 3, 2021 | 07:29 PM
BluegrassMotorsport's Avatar
BluegrassMotorsport
Autozone Duralast Gold, no question about it. Great bite, no squeaks, and significantly less brake dust than the OEM pads. Best part - they're affordable.
Old Jan 3, 2021 | 07:44 PM
HK770's Avatar
HK770
Auto Zone Duralast Gold Pads and fluid exchange and bleed. Bleed LR-RF....RR-LF ( Inner port first ....then outer port )
https://www.ebay.com/itm/Motive-Prod...gAAOSwWWxY~ths
Old Jan 3, 2021 | 08:28 PM
Keppler's Avatar
Keppler
St. Jude Donor '25-'26
For a street car chose dustless ceramic pads and the above suggestion to bleed the brakes with new fluid is something you definitely should do.
While you are at it do the Ranger method for the clutch fluid if you have a manual transmission.
Old Jan 4, 2021 | 09:11 AM
farmington's Avatar
farmington
I used Hawk HPS pads. Very low dust. Very low noise. Great bite.
Old Jan 4, 2021 | 10:47 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
For a high quality low dust performance street brake pad take a look at the Carbotech 1521 brake pad 100% non-corrosive dust will not harm your wheels, paint or rotors. Carbotech brake pads are 100% made in the USA and can be ordered online here http://ampdautosport.com/brake-pads/corvette/ or call me at 216-780-8825. The part numbers you need are front CT1185-S and rear CT1185R-S Listed under C6 ZO6. Use promo code z28 at check out to receive your forum discount.
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Old Jan 6, 2021 | 09:39 AM
okgo's Avatar
okgo
What is the best way change brake fluid and bleed
Old Jan 18, 2021 | 12:36 AM
Allan's Avatar
Allan
St. Jude Donor '14
Old Jan 18, 2021 | 04:41 PM
SG4247's Avatar
SG4247
I just did all 4 in my 2008 Z06 with 38k miles.
No one in OKC would turn the rotors due to the cross drilled holes. So, I bought 4 new rotors from GM.
Bought the full set of Carbotech bobcat 1521 1 piece pads.
Very good pads, no noise, low dust, great feel. A little expensive in my opinion.
These are great street pads, but they dont have the same initial bite as the factory padlets. These are not track pads either, I noticed a difference after a few 150mph hard stops. But they are great for a street car. They are great for my weekend drag strip habit, but not for road racing.
Very good pads.
Old Jan 19, 2021 | 11:55 AM
Spaceme1117's Avatar
Spaceme1117
This. I replaced mine last year to cut down on the dust versus OEM.
I did not change my rotors as they were still in good shape. I also did not resurface them.
I also did not do any break-in or re-bedding (maybe should have). But I also have not noticed any change or decrease in stopping power.
To Brake job
